Constant pressure confusion.
So, in summary, to find the energy input required to raise the temperature of the air in the vertical cylinder with a heavy piston from 315 K to 755 K, you need to use the equation Q = n * Cp * ΔT and also factor in the work done.
lackos
38
A vertical cylinder with a heavy piston contains air at 315 K. The initial pressure is 2.85 105 Pa, and the initial volume is 0.250 m3. Take the molar mass of air as 28.9 g/mol and assume CV = 5/2R.
(d) Assume again the conditions of the initial state and assume the heavy piston is free to move. Find the energy input required to raise the temperature to 755 K.
4 kJ
Q=nCp(delta)T;
and possibly;
(delta)E=Q+W
im confused as to whether all i need to use is the first equation or if in need to factor in the work done.
i already have to number of moles and Cp=7/2R
Thanks!
I would say that you also need to calculate the work done. Because the piston is "free to move". If the piston has moved, there has been a change in the volume. If there is a change in the volume, there is work done.
What is constant pressure confusion?
Constant pressure confusion refers to a phenomenon where individuals experience a sense of mental and emotional pressure, often accompanied by feelings of stress and anxiety, on a regular and ongoing basis.
What are the causes of constant pressure confusion?
The causes of constant pressure confusion can vary from person to person, but common factors include high levels of stress, overwhelm, and an inability to effectively manage and cope with daily challenges and responsibilities.
How does constant pressure confusion affect individuals?
Constant pressure confusion can have a significant impact on an individual's mental, emotional, and physical well-being. It can lead to feelings of exhaustion, burnout, and difficulty focusing and performing daily tasks.
What are some strategies for managing constant pressure confusion?
Some strategies for managing constant pressure confusion include practicing self-care, setting boundaries, seeking support from loved ones, and developing healthy coping mechanisms such as mindfulness and relaxation techniques.
When should someone seek professional help for constant pressure confusion?
If constant pressure confusion is significantly impacting one's daily life and functioning, it may be beneficial to seek professional help from a therapist or counselor. They can provide support and guidance in managing and coping with the underlying causes and symptoms of constant pressure confusion.
