Can a Proper Map Preserve Integral of Smooth n-Forms with Compact Support?
In summary: If it means something else you should clarify in your post and you would get much better advice in a much more timely... um... manner.
daishin
27
Let f:R^n-->R^n be a C^oo proper map. Suppose there is a real number r such that f(x)=x for all x in R^n with |x|> r. Show that for every compactly supported smooth n-form w on R^n
integral of f*w = integral of w. Here, integral is defined on R^n.
I think this problem implies that when the condition above holds, we cannot construct a map from R to R s.t integral of w =/= integral of f*w which is not obvious for me.
Could anybody provide a solution of the problem?
I don't even believe this result.
daishin said:
Let f:R^n-->R^n be a C^oo proper map. Suppose there is a real number R
you mean "r"?
What text did this problem come from?
Sorry
Yes it is a real number r. not R. I don't know which textbook has this problem.
it's just that the problem doesn't seem completely well-defined. The integral over what "volume"? over the ball itself? Then it seems trivial... is what you have given the entire statement of the problem?
I think the problem is well defined. Integral is defined on R^n, the n dimensional real space.
...but f is not defined in all of R^n...
Why not? Maybe you are thinking that the map f is defined on r^n-->r^n.
But f is defined between R^n, the n dimensional real space.
No. No, that is not what I am thinking. Obviously, that doesn't make any sense.
What I mean is that you have only defined the function f for |x|>r in your original post.
Look at your original post and tell me, what is the value of f when x=0? How about for any region surrounding x=0 but with |x|<r. Yes, please... do tell: what is the value of f then?
It is not specified... so, then... If the integration region contains, say, some volume surrounding x=0 then how am I supposed to make any statement about the value of the integral?
Oh.. I see what you mean. But still the problem is well defined. Initially, we don't know what the value of f is for any region |x|<r. If you think this problem is simply wrong, then could you provide an example of any function f which satisfies the condition in the problem and that the integral of f*w =/= integral of w?
Initially? I'm not sure what you mean by that, either you know f or you don't...
If f is not specified then, indeed, you can not do the integral in general.
If we check that there exists a C^oo proper map from R^n to R^n which satisfies the condition in the problem, then either the statement
[integral of f*w = integral of w for all such f] is right or wrong.
The condition is that there is a real number r such that f(x)=x for all x in R^n with |x|> r. The identity map from R^n to R^n satisfies the condition.
So either integral of f*w = integral of w is right or wrong.
So although initially(when we just looked at the problem) we don't know what f is, the problem is well defined. I don't think we can determine what function f is even after when we solve the problem. But I am not sure.
okay, then the answer is "wrong."
I.e.,
[tex]
\int f w \neq \int w
[/tex]
oh, wait a second... you have f*w... um... in that case, maybe it's correct. what's the star mean?
daishin's notation and intent is really opaque, but I believe what he is being asked for is just a proof of the change of variables formula. E.g. integral(df)=integral(f'(x)dx). f*w can't mean an ordinary product since f takes values in R^n, it has to mean the change in the n-form induced by the change of variables f. I've looked at this several times today and finally figured out what the OP is talking about.
Why?? Could you provide an example of f such that the integra of f*w is not equal to the integral of w?? By the way, do you know what f* means??
I edited my post above. can you explain the star.
f*w means f times w to us laymen. If it means something else you should clarify in your post and you would get much better advice in a much more timely fashion.
olgranpappy, if you missed my post, he's looking for a change of variables formula.
I don't understand why the proof of integral(df)=integral(f'(x)dx) is related to my question. Could you explain more?
f* is a pull back if f is defind from M to N then there is a map f* from the differential forms on N to a differential forms on M
In one dimension f'(x)dx is the change in integration measure induced by the change of variables x->f(x). I'm assuming that's what your f*w means.
I caught it. I really hate this math-notation. They need to hang indices off everything like us physicists. Anyways, I think his question is not exactly about a change of variables...
it looks like one is going to have to use the fact that because f is smooth and because it's equal to x everywhere outside some finite region then also f(x) is roughly equal to x almost everywhere, or everywhere as far as the measure in concerned such that the integrals are equal...
I obviously jumped into trying to give an answer too quickly since I still don't know what his star notation means. Cheers.
Yes, the pullback. Same thing. Can you think how to extend the calculus change of variables formula to an n-manifold and n-forms?
It's never too quick to jump if nobody else is jumping. Watching you struggle with the problem cleared it up for me, finally. f*w may be standard notation in the OP's class but not here. Mention of the word pullback might have helped. If only everyone were more like 'us physicists'.
I shall come back tomorrow. Any help would be appreciated!
An integration of a differential form involves an integration over chains (coordinate volume elements) of a form. You have to show that for the change of variables x->f(x) that the change of the form cancels the change in the chains.
What is an integral map?
An integral map is a graphical representation of an integral, which is a mathematical concept used to calculate the area under a curve. It shows the relationship between a function and its integral over a given range.
What is the purpose of constructing an integral map?
The purpose of constructing an integral map is to visualize and better understand the concept of integration. It can also be used to solve complex integration problems and make predictions about the behavior of a function over a given range.
How is an integral map constructed?
To construct an integral map, you first need to choose a function and a range over which you want to calculate the integral. Then, you divide the range into smaller intervals and calculate the area under the curve for each interval. These areas are then plotted on a graph, with the x-axis representing the intervals and the y-axis representing the areas. Connecting the points on the graph will give you the integral map.
What are the benefits of using an integral map?
An integral map can help make the concept of integration more tangible and easier to understand for students and researchers. It can also be used to verify the results of integration and identify any errors in the calculations.
What are some common applications of integral maps?
Integral maps are commonly used in various fields of science and engineering, such as physics, economics, and statistics. They are also used in real-world applications, such as calculating the area under a demand curve in economics or determining the velocity of an object in physics.
  • Math POTW for Graduate Students
