B Continuity of photons
Summary
Is there experimental evidence for photon conitinuity.
In the double-slit experiment, is there experimental evidence that a photon detected passing a slit always results in one and one only screen point?.
vanhees71
Insights Author
5,352
Well, with there's always some probability that a photon is not registered, but if it's registered then at one point and only one point of the screen.
Thanks. So that a photon behaves as a 'particle' in the classical sense - that if at one point in time it is found at some point, then at a later point in time it will be found at some other (not necessarily predictable) point - is in fact not experiementally demonstrable.
A. Neumaier
Insights Author
6,997
2,903
No, because whenever a photon is detected, it ceases to exist.
Right. So photon continuity is an unverifiable hypothesis. Which doesn't of course mean that it is untrue. But just that in practice it is at present experimentally unverifiable.
A. Neumaier
Insights Author
6,997
2,903
Nobody claims it anyway.
Photons are just a fancy name for detector clicks in response to faint light. In addition they are a a technical name for ingredients building up the state of electromagnetic radiation.
But delayed eraser experiments, for instance, DO imply particle-like continuity: that an idler photon arriving in a detector corresponds to a signal photon point on the screen.
A. Neumaier
Insights Author
6,997
2,903
This is just a figure of speech for a more complicated situation.
It allows one to reduce the discussion to the essentials but is misleading when taken literally.
Ok. Thanks.
In the Mach-Zender 'particle' setup, would it be true to say that a photon is detected either in one detector, or in the other, but never in both simultaneously?
DrChinese
1,014
Thanks. So photons are at least more trustworthy than atoms.
DarMM
1,388
Note there is no state that will definitely cause ##N## clicks in an appropriate device.
In a sense a "one photon" state just means a state of the electromagnetic field very likely to cause one click in a photon detector, but not certain to.
A. Neumaier
Insights Author
6,997
2,903
Generally, that's the right idea. This experiment spells it out pretty well. 1 photon, 1 click.
No. There is always some loss due to detector inefficiency. The 1-1 correspondence is just a convenient simplification.
f95toli
439
This is ultimately a philosophical question: what does "exist" mean?
The vast majority of people working with photons do think of them as being as "real" as e.g. atoms, but this does of course not mean that they are in any way classical objects,
DrChinese
1,014
No. ... The 1-1 correspondence is just a convenient simplification.
Well, I used the word "generally" (indicating a "convenient simplification") and cited the specific experiment itself in case anyone wanted to see more depth; I'm not sure how you can say NO to that as an answer to a simple question. :smile:
We agree that every experiment has some degree of inefficiency, so I don't see the value of your contrary conclusion. Yes, 1:1 is the relevant takeaway here - and you would get that with perfect efficiency (if there were such a thing). In fact, as mentioned in the reference: "a single photon can only be detected once!*"
IMHO: We do a disservice to some readers when we qualify things so much that the original question gets completely lost.
*Originally Grangier, Roger and Aspect, 1986.
A. Neumaier
Insights Author
6,997
2,903
We agree that every experiment has some degree of inefficiency [...]
Nevertheless, the only correct B-level answer to the original question
is no.
The experimental evidence is overwhelming that a photon passing undetected a slit always results in zero or one screen point, never more. A zero count is due to detector inefficiencies.
On the other hand, if the photon is detected passing a slit it disappears and always results in no point on the screen.
"The experimental evidence is overwhelming that a photon passing undetected a slit always results in zero or one screen point, never more."
In SPDC terms: "there is overwhelming experimental evidence that if an idler photon is detected, then in principle one and only signal photon will necessarily be detected. And if it isn't, this will be attributed to detector inefficiency" (correct?).
"No. ... The 1-1 correspondence is just a convenient simplification."
This is the essence of my query. Is the near 1:1 ratio due to a given wave amplitude generally resulting in a photon detection at both points (slit and screen)? Or is is a necessary condition due to the particle properties of photons. And that if a photon is detected at one point and not the other, then this must be due to detector inefficiency at the no-show point.
A. Neumaier
Insights Author
6,997
2,903
If only one photon is around at the time of measurement, there can be only one detection event.
(But you seem to be discussing here the case of an entangled pair of photons, an idler photon and a signal photon. For this, there are two possible detection events.)
No. One can detect a given photon only once, as it is destroyed by the detection process. Hence only at the slit or at the screen, not twice. But because of detector inefficiency, both detectors can possibly miss it.
But do these in principle (ie. ignoring detection inefficiency) always correlate: if one is detected, then the other necessarily will be; and if not then not?
A. Neumaier
Insights Author
6,997
2,903
The detection failures are independent. But assuming 100%efficiency, two photons imply two detection events. This has nothing to do with correlations.
DrChinese
1,014
You are talking about PDC pairs. So the answer is YES, despite everything being said that might indicate otherwise. When one of the pair goes through a double slit, and since it is a photon: it only has the opportunity to be detected once. That is what A. Neumaier is pointing out, and there is no argument about that. The key takeaways are:
a. There is 1 click at both detectors, or no clicks at either*. That is what you refer to as "correlated"; which is often used with PDC to mean something a bit different (again why A. Neumaier's answer is different than mine). But you are correct generally, that is the entire point of the reference I provided.
b. There are never cases of 1 click at one detector*, and 2 (or more) clicks at the other. That is because a PDC pair - sometimes referred to as a biphoton - is a special state with a known photon number (2 in this case). Such a state is called a Fock state. Most light does not appear in this state, as photon number is not usually a conserved quantity. In fact, PDC photon pairs are created from a single input photon (in those cases where a biphoton results).
c. Although often ignored with a double slit setup: it IS possible to determine which slit a photon goes through without destroying it. That's another subject though. :smile:
d. You should never make assumptions about what quantum particles are doing - at least not rigorous assumptions - when not being observed. They have a nasty habit of doing the impossible when you make an assumption which is reasonable yet wrong.
Now obviously, and as A. Neumaier correctly points out, there are many details being glossed over in our discussion. You can read more at the reference I provided. It is very good as it is intended for an undergrad lab. Note that this experiment soundly refutes one of the classical views of light.
*Of course many photons that are part of PDC pairs never make it through the double slit in the first place (in your setup); so we are ignoring that for the purposes of our discussion.
vanhees71
Insights Author
5,352
is no.
This is a bit strange formulation for a beginner.
Fact is that there is some probability for a single photon, which state can be prepared today easily via parametric downconversion, to be detected by a detector or not.
If photon is detected and if the detector resolves the position of the detection event a single photon state is registered at one "point" (a point has of course necessarily a finite size) and not as a smeared distribution. That's one of the most simple indications for the necessity of field quantization. It cannot be explained within classical electrodynamics.
vanhees71
Insights Author
5,352
No, it doesn't contradict anything, but I hope it makes it more clear to a beginner in QED.
Want to reply to this thread?
"Continuity of photons" You must log in or register to reply here.
Related Threads for: Continuity of photons
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
Hot Threads
