Photon Continuity in Double-Slit Experiment
In summary, the evidence in the double-slit experiment suggests that a photon detected passing a slit behaves as a 'particle' in the classical sense - that if at one point in time it is found at some point, then at a later point in time it will be found at some other (not necessarily predictable) point.
  • #71
charters said:
To be clear, I am not claiming a photon/any particle has *classical* path, I am just claiming it is reasonable to say the photon/any particle was present along the superposition of possible spacetime paths between emission and absorption, after accouting for interference among such paths.
I think the problem is that QM is silent on the question of path (because of the nature of the model) that does not mean the (single)particle doesn't have a path. But if you have model that does predict the path( electron or photon) you are welcome to publishing it.
Likes vanhees71
  • #72
vanhees71 said:
Well, with there's always some probability that a photon is not registered, but if it's registered then at one point and only one point of the screen.
When you say one point what does that mean, that the photon is absorbed by a single atom?
  • #73
The closest thing to a "path" is imho a sequence of observations as produced in a cloud chamber and is well understood in a now classical paper by Mott:
https://doi.org/10.1098/rspa.1929.0205
Likes DarMM
  • #74
DarMM said:
Coherent states are just a simple example. As you said they're not particle states and their operators don't commute with particle operators. So we have non-particle states that are complimentary to particle ones, thus you can't really think of particles as being fundamental since there are observables that are complimentary to them.
I think the issue I was trying to focus on got lost yesterday- I really was not at all trying to say particle states as eigenstates of the number operator are fundamental. So, above you said:
DarMM said:
People are lead to think photons are something that hits the camera and causes the excitation of a pixel, where as under QED it is more the case that a photon is the excitation of a pixel in a camera and QED gives rules for the probability of a given pixel being excited a given amount.
I didn't read this claim as having anything to do with the EM/photon field being in specifically a particle state or not. It seems to apply just as much to coherent states. I read this as a rejection that anything "hits" detectors, or travels between detectors, and so all we have are the correlations among macro detectors that spontaneously click due to some notion of causally delayed direct action.
But are you saying instead that you do think that EM field excitations in some general form traverses the spacetime between source and detector, but that the discreteness of detector responses, naively attributed to the field being in a pre-existing discrete n-particle state, is in fact just a feature of the field-detector (or more generally field-atom) interaction?
  • #75
It's not a rejection that something interacts with the detectors, or a proposal of direct action. It's a just a statement of what seems to happen in QFT. When a light source (or more generally a matter source) causes an effect in a given detector, if the detector is of an appropriate design and placed far enough away from areas of interaction then the effects on the detector can be understood in particulate terms using asymptotic particle states. If not, then it can't.
Thus particles are only associated with late time detectors placed appropriately.
Likes vanhees71
  • #76
QM simply doesn't use paths at all. I think this is "silence" in the same way GR is silent about the universe being embedded in a larger spacetime. Similarly Maxwellian electromagnetism is silent on the notion of the EM field being a limiting case of some more general field.
Really the success of QM shows the notion of paths just doesn't seem to be needed at all for current observations.
I think it should be mentioned that attempting to come up with paths for particles is highly constrained by no-go theorems such as the Kochen-Spekcer theorem and the PBR theorem.
Likes dextercioby, vanhees71 and weirdoguy
  • #77
vanhees71 said:
Consequently also a "particle-number observable" is available only for asymptotic free states. The interpretation of "transient states" in scattering processes in terms of "particle states" is at least problematic. If I understand @DarMM right, it's even mathematically impossible within mathematically more rigid formulations of the theory!
Sorry forgot to answer this. Yes indeed, impossible.
Likes vanhees71
  • #78
Sorry for the delay, but I wanted to follow up on this. Suppose we have a macroscopic device which experimentalists would consider a good single photon source. What would be a concrete (can actually be built) detector of appropriate design which we could use to measure this emission in such a way that the effect could *not* be understood in terms of an asymptotic 1 photon state?
  • #79
Well if the source is defined in terms of a single photon state, the statistics of experiments are going to be compatible with a single photon state. This is like how if you prepare a momentum (near) eigenstate the statistics of any experiment are going to be compatible with a momentum eigenstate, both position and momentum measurements. Simply because that is the state. However the statistics in the two bases exhibit complimentarity. Thus it is for a single photon state, it can be measured in a non-photon basis. However even ignoring this most states in quantum optics are not single photon states and even calling something a "single photon state" is an idealisation.
Asher Peres has some interesting points (https://arxiv.org/abs/quant-ph/0212023):
Although states with a definite number of particles area useful theoretical concept, a look at quantum optics techniques or at the Table of Particle Properties shows that experimentally accesible quantum states are usually not eigenstates of particle number operators. In general any process that is not explicitly forbidden by some conservation law has a non-zero amplitude (Weinberg, 1995;Peskin and Schroeder, 1995; Haag, 1996). There are multiple decay channels, extra soft photons may always ap-pear, so that the so-called ‘one-photon’ states are often accompanied by soft multiphoton components,
##\alpha|\Omega\rangle + \beta|1_{\omega}\rangle + \gamma|2_{\omega^{′}\omega^{′′}}\rangle +..., |\beta|∼1## (63)
Thus the physical realization of a single qubit is itself necessarily an idealization.
So a single photon state is a more fraught concept than one would think.
  • #80
Right, I am just asking how exactly this can be done in practice. Typically (afaik) a coherent state is measured by 1) recording the number of clicks across many runs, 2) treating each click as indicative of an individual photon, 3) confirming the distribution of clicks converges to the Born rule distribution of the number states which describe the coherent state in the number basis. I am not aware of a detector which can directly measure radiation on a non-number basis.
Likely I am just missing a counterexample because I haven't been exposed to all the experimental possibilities but I haven't had luck finding one so far.
  • #81
Homodyne detectors are probably the simplest examples.
Likes charters
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
