Homework Help: Continuity on an interval
  1. Feb 2, 2009 #1
    Suppose a function is continuous at a point, c. Does this mean there exists an interval around c which is also continuous?
    If so prove
    2. Relevant equations
    3. The attempt at a solution
  3. Feb 2, 2009 #2
    Dick
    Any opinion on whether it might be true or not? Doesn't seem true to me, but that's just an opinion also because I can't think why it would be. You might try to find a counterexample first.
  4. Feb 5, 2009 #3
    it boils down to the definition of the limit.
    for all e>0. there exists s>0 such that
    if x satisfies abs(x-a) then abs(f(x)-a)<e
    the question is: Does f have to be defined on the interval abs(x-a)?
    example of this- A function is undefined at every point except a.
    does the limit exist at a?
    if yes, then we have a trivial counterexample to the original post
  5. Feb 5, 2009 #4
    Dick
    The counterexample isn't that trivial. Define f(x)=x if x is rational and f(x)=0 if x is irrational. Where is that continuous?
  6. Feb 5, 2009 #5
    ah, thanks for the counterexample.it would only be continuous at 0.
    My second post was to clarify a technical point.
    If f is undefined at every point except a, and defined at a, is f continuous at a?
  7. Feb 5, 2009 #6
    Dick
    Continuity says as x->a, f(x)->f(a). If there are undefined points arbitrarily close to a, I would say no, it's not continuous. If you say the definition is x->a AND f(x) defined at x, then you could say yes, it is. A 'function' with 'undefined' points is a little ambiguous. In any event, even you decide to call it technically continuous, it's not a very interesting example, is it?
