Continuity Proof
  • Thread starter tvguide123
Suppose that "f" satisfies "f(x+y)=f(x)+f(y)", and that "f" is continuous at 0. Prove that "f" is continuous at a for all a.
In class we were given 3 main ways to solve continuity proofs.
A function "f" is continuous at x=a if:
a.)
Limit of f(x) as x->a = f(a), (a can be all real numbers)
b.)
Limit of f(a+h) as h->0 = f(a), (Let x=a+h)
c.)
(delta-epsilon proof)
For all epsilon greater than 0, there exists some delta greater than 0, such that for all x, if |x-a|< delta then |f(x)-f(a)|< epsilon.
So far, by working with my teacher I was able to get this much as being correct:
Theres not enough information for a delta-epsilon proof so
Were told that f(x+y)=f(x)+f(y), for all x,y belonging to real numbers then
In partiality:
f(0+0)=f(0)+f(0)
f(0)=2f(0)
Only way this can be possible is if f(0)=0
hence f(0)=0
Now consider:
Limit of f(a+h)-f(a) as h->0 is equal to 0.
Im not as to what i should do now and what the second part that my teacher wants me to consider will prove.
Any ideas would be greatly appreciated!
Answers and Replies
CompuChip
4,306
48
Use the information given. You can rewrite f(a + h) - f(a) to reduce the problem around a to a problem around zero.
How can I reduce the problem to be around zero?
Also what does this prove?
CompuChip
4,306
48
OK, firstly: do you see what [tex]\lim_{h \to 0} f(a + h) - f(a) = 0[/tex] is good for?
Then, note that you have been given that f is continuous at zero and you want to prove continuity at some arbitrary a, about which you don't know anything. So you can try to use the properties you have to make the problem of continuity at a into a problem of continuity at 0, because you have more information of f around 0 than around a.
HallsofIvy
41,847
969
You have to use the fact that f(x+ y)= f(x)+ f(y). So f(a+ h)= ?
Related Threads on Continuity Proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
