Could Einstein's Theories Allow for Negative Mass-Energy?
In summary, John Shoemaker proposes a model of the universe that allows for the creation and annihilation of particles with non-zero probabilities. He suggests that this could explain the lack of perception of m- matter in laboratory settings and potentially reconcile Einstein's theories with negative mass-energy and a net density of 0. However, there are still questions and concerns about the evidence for the creation of neutrons and the dynamics of galaxies in this model.
john shoemaker
Einstein repeatedly noted that the his theory didn't preclude negative mass-energy. He wrote that he wouldn't elaborate on it in a physical theory since it had not been physically observed. His predilection for a net density of 0 can be seen in his writing as is his almost plaintive admission that "this does not appear so." He never wavered in his disallowing of physical singularities and could he have known of their popularity soon after his death he likely would be especially receptive to a possibility that would preclude them and provide tests for which data might (and did) soon appear.
Model of Universe Allowing Probability of Creation of Particles
This model holds that all existing particles have non-zero probabilities for creation and annihilation (Pc, Pa) and these same probabilities exist for particles of like observable descriptors except that the mass is negative and equal in quantity---- |m-| = |m+|. (Pc=particles/time-cubic three space, Pa = particles/time. Probabilities operate in proper space-time).
In laboratory of m+ matter observation of E/M interactions between m- and m+ matter inhibited by lack of m- matter. This lack of perception within the laboratory produces difficulty in conceiving of possible E/M interactions between m+ instruments in the laboratory and m-matter at large distance. m- collections thus appear transparent, unusually devoid of m+ matter.
The probability for creation of neutrons apparently being considerable, this is the only probability considered here. Particles of one type of mass will tend to collect gravitationally and repel oppositely massed particles. M(sum of m+ minus sum of m- within a radius r) divided by |M|( sum of m- plus sum of m+) tends monotonically to zero as r increases about any point. Likely GR will agree that E/M and other physics of m- matter are similar to that for m+ matter.
A collapsing m+ neutron star will speed clocks of m- matter . These "clocks" acting thru Pc preclude developed black hole: the formulas below relate to neutrons entering a sphere of radius R(inside neutron star) at velocity dr/dt.
Density at its surface is D(finite number).
dm/dt, R, D are observed, measured far from star.
dm+/dt = 4 xPi x Rsquare x D(R) x dr/dt < 4 x Pi x Rsquare x D x C (light speed=1)
dm-/dt > Pc x 4/3 x Pi x R^3 (1+ M/2R)^3 over 1-2M/R.
M = D x volume of sphere of radius R. Note that when integrating IntD/r over this sphere to get metric-- ruler-clock expansion factor, the largest r between any mass element and any 3space element for which we desire the factor is 2R. Thus actual expansion factor greater. Note we are ignoring mass outside the sphere.
If R is such that M(R)/2R is close enough to 1 that dm-/dt > dm+/dt (note that expansion of rulers goes to 2) that is:
Pc x 4/3 x Pi x 2^3 R^3 over 1-M/2R > 4 x Pi x R^2 x D
or Pc x 8/3 R over 1-M/2R > D --- then
net mass within radius R does not increase. The alternative to the above "If" is that there is no R such that M / 2R approaches one. m- neutrons appearing within high enough density of m+ neutrons will annihilate with m+ neutrons(QM extrapolation)
Very large collections of m+ matter containing much hydrogen will present high energy(fusion energy) and low particle density which decreases probability of annihilation of m+ and m- matter and thus escape of m- matter. Local region of order 10^10 Ly possibly artifact of prior collapse of region of this order and subsequent fusion-excursion expansion. Or, local region of apparently expanding m+ results from prior collapse of m- region with subsequent productin of core of m+ which produced m+ core that initially maintained integrity and pressure for large scale fusion energy until it could repel m- collapsed matter. Again producing observed expansion through globs of m-.
A large region of relatively constant density m- matter containing a smaller void(perhaps due to presence of m+ matter there) can be handled in the elementary physics classroom by imagining the region to have no void but have imbedded in the m- dominated region a small region of m+ matter of absolute density equal to the "average" density of the voided region of m- matter. A void induced by an m+ galaxy in a large m- region could be approximated as a sphere of m+ matter of radius of order of the galaxy. As the gravitational(centripetal) effect of this incompressible imaginary matter would proceed from 0 at r=0 to maximum at the surface, far observation would show that the outer reaches of the galaxy suffer a higher central attraction(and velocity) than more central matter. This effect is superimposed on the effect of the visible(m+) matter Resulting angular velocity of far-off matter would approach a constant versus r. Matter near center would exhibit usual mv^/r = mM/r^2 velocity
A compact enough galaxy cluster could induce above Elem. Phy. void of cluster size thus effecting the dynamics of peripheral galaxies within the cluster more than central ones in their co-orbiting. Individual galaxies would not exhibit the appearance of higher central attraction for peripheral matter. Individual galaxies in less compact clusters would exhibit combination of above dynamics.
Thank you for your consideration,
John Shoemaker
Dear John Shoemaker,
Thank you for sharing your model of the universe with us. It is certainly an interesting and thought-provoking concept. I appreciate your efforts in trying to reconcile Einstein's theories with the possibility of negative mass-energy and the idea of a net density of 0 in the universe. Your explanation of the lack of perception of m- matter in laboratory settings is intriguing and could potentially explain some of the mysteries surrounding dark matter.
However, I do have a few questions and concerns about your model. First, you mention that the probability for creation of neutrons is considerable, but what evidence do we have for this? Have we observed the creation of neutrons in this way? Also, your equations and calculations seem to rely heavily on the assumptions and extrapolations of quantum mechanics. While this is certainly a valid approach, it does raise questions about the accuracy and applicability of your model.
Additionally, your concept of a void induced by an m+ galaxy in a large m- region is interesting, but it seems to contradict our current understanding of gravity and the distribution of matter in the universe. Can you provide any evidence or observations that support this idea?
Overall, I think your model has potential, but it would benefit from further research and experimentation to test its validity. Thank you again for sharing your ideas with the scientific community. Collaboration and open-mindedness are crucial for advancing our understanding of the universe.
What is Continuous Creation?
Continuous Creation is the scientific concept that suggests the universe is constantly expanding and evolving, with new matter and energy being created at a continuous rate.
How does Continuous Creation differ from the Big Bang Theory?
The Big Bang Theory proposes that the universe was created in a single event, while Continuous Creation suggests that the universe is constantly expanding and evolving with no definite beginning or end.
What evidence supports the idea of Continuous Creation?
One of the main pieces of evidence for Continuous Creation is the observation of distant galaxies moving away from us at accelerating speeds, indicating ongoing expansion of the universe. Additionally, the discovery of new stars and galaxies in previously empty areas of space supports the idea of continuous creation of matter.
What are the implications of Continuous Creation for the future of the universe?
If Continuous Creation is true, then the universe will continue to expand and evolve indefinitely. This could eventually lead to the heat death of the universe, as all energy is spread out and becomes unusable.
How does Continuous Creation relate to the concept of entropy?
Entropy is the measure of disorder or randomness in a system. Continuous Creation suggests that the universe is constantly increasing in entropy as new matter and energy are being created. This aligns with the second law of thermodynamics, which states that entropy always increases in a closed system.
  • Beyond the Standard Models
