Contravariant & Covariant Vectors: Electric Field Case
  • Thread starter Coffee_
  • Tags
    Covariance
In summary, a vector can be either covariant or contravariant. This will depend on how the coordinates of this vector transform under a coordinate transformation.
Coffee_
259
From what I understood, a vector can be either covariant or contravariant. Which one this is will depend on how the coordinates of this vector transform under a coordinate transformation. Let's take a look at the electric field then:
##\vec{E}=-\nabla{V}##, so here it looks as if the electric field is covariant.
However if we have a particle in space, it will accelerate due to this electric field and now the electric field can be expressed as :
##\vec{E}=c\vec{a}## where ##\vec{a}## is contravariant , and so here it looks like the electric field is contravariant.
So is my understanding about vectors being either covariant or contravariant incorrect?
A relativist's answer would be that the electric field is not a vector at all, because it doesn't transform as any kind of vector. The electric and magnetic fields together make up a tensor.
Anyway, as long as you have a metric, any vector can have its indices raised or lowered, so it can exist in either covariant or contravariant form. One can worry about whether it's more natural to consider a certain vector as covariant or contravariant, but such a worry is pointless in the context of relativity, where we always have a metric.
It is the same vector expressed in a different way. We can write a vector V either as ##V^\mu## or ##V_\mu##.
Is this an alright way to think about it?
''Vectors themselves are either solely contra or covariant. However with physical quantities like the electric field, come two different vectors, one covariant and one contravariant which can be transformed into each other with the metric?''
This is bad new for my few hours of studying this subject, my understanding of the concepts is all wrong then. So we cannot call a vector ''covariant'' or ''contravariant'' any vector however has contravariant and covariant components?
I would not put it that way. Any vector of the one type can be converted into a vector of the other type using the metric tensor: [itex]V_\mu = \sum_\nu g_{\mu \nu} V^\nu[/itex]. But for 3-vectors in Cartesian coordinates, the metric tensor is trivial: [itex]g_{ij} =0 [/itex] (if [itex]i \neq j[/itex]) and [itex]g_{ii} = 1[/itex]. So for 3-vectors in Cartesian coordinates, [itex]V^j = V_j[/itex]
Why not ? When an index is raised or lowered the components change.
Not true. I can for example take Cartesian coordinates and rescale them uniformly. The result is then a different set of Cartesian coordinates with a different metric tensor.
In any case, the reason all of these concepts were invented was precisely so that we could be permissive about coordinate systems rather than prescribing a preferred set of coordinates.
Why not what? Why not say that a vector with components [itex]V^\mu[/itex] is the same as a covector with components [itex]V_\mu[/itex]?
Because they are fundamentally different geometric objects. If you have a metric tensor (which you usually do for vectors in space), then you can convert between them, but they are very different types of objects.
The example I like to give is atmospheric pressure, which is a function of temperature and altitude on the Earth. So you can make an abstract space with one variable, [itex]T[/itex] being temperature and another variable, [itex]H[/itex] being altitude. Pressure would be a scalar field [itex]P(T,H)[/itex] on this abstract space.
Now, in this abstract space, there are two very different types of vector-like objects. Given a scalar field such as [itex]P[/itex], we can construct a vector describing how [itex]P[/itex] varies with "location" within the 2-D space:
[itex]\nabla P[/itex] has components [itex]P_T = \frac{\partial P}{\partial T}[/itex] and [itex]P_H = \frac{\partial P}{\partial H}[/itex].
On the other hand, if both [itex]H[/itex] and [itex]T[/itex] are varying with time (because you're in a car traveling into the mountains), then you can track your position through the abstract space using an abstract "velocity" [itex]V[/itex] with components [itex]V^T = \frac{dT}{dt}[/itex] and [itex]V^H = \frac{dH}{dt}[/itex]
[itex]V[/itex] can ONLY be a tangent vector, which is something with contravariant components. [itex]\nabla P[/itex] can ONLY be a covector, which is something with covariant components. There is no "metric" that would allow you to convert one type of vector to another.
bcrowell said:
Not true.
Well, it is true that in 3D you can often get away with not distinguishing between vectors and covectors. They don't typically teach the distinction until Special Relativity and sometimes not until General Relativity.
Anyway, I think we're on the same side here. I think that in general tangent vectors and covectors (or one-forms) are very different objects, and they only seem interconvertible because we have a metric.
Likes bcrowell
You don't seem to have such similar views to me. So a vector is either covariant or contravariant and can be converted to a different vector that is the opposite when you have a metric?
stevendaryl correctly points out that when we come to give numbers to the vectors, tangent space vectors are contravariant and their derivatives are contravariant. If I measure a velocity in some x-direction, I'm measuring the x component of a contravariant vector.
But in any expressions we are free to write a covariant vector with its contravariant components if we want to.
So ##V^\mu V_\mu## still makes sense whether ##V## is a tangent space vector or not. So, in these terms. ##V^\mu## and ##V_\mu## represent the same vector.
I don't think we disagree at all.
"Getting away with not distinguishing vectors and covectors" is not really about the dimensionality of space, but more about the Euclidean metric (that is, the Pythagorean theorem) in arbitrary dimensions. If you have a Minkowski-signature metric in 3D, the rectangular components of a vector differ from that of its metric-dual covector.
Dimensionality comes when one tries to think of, e.g., the "cross-product of two vectors" as another vector [of the same type]. In that example, there will be issues of polar vs axial vectors... which we never add together.
While there may be a metric ##g_{ab}## lying around that takes a vector ##V^a##
to form the metric-dual covector ##g_{ab}V^b## (which is written in shorthand as ##V_a##),
one still has to distinguish them because they cannot be meaningfully added together... it's like adding a column vector to a row vector (which MATLAB might not let you do).
While we might get away with that in Euclidean space, we'll run into trouble in other spaces.
Likes JorisL
Right. I just brought up 3D because the 3D part of the metric for flat spacetime is Euclidean. There's nothing special about the number 3, except that that's the number that's relevant in most physics classes, which is where vectors are typically introduced.
Right, the fact that in 3D, antisymmetric bivectors can be thought of as vectors is another source of confusion about the nature of different mathematical objects.
Well, the original poster was asking about this very issue: If [itex]\frac{d^2 x^j}{dt^2}[/itex] is naturally considered a vector (with contravariant components), and [itex]\frac{\partial}{\partial x^j} V[/itex] is naturally considered a covector (with covariant components), then how does it make sense to equate them, which seems to be the case when we write:
[itex]m \frac{d^2 x^j}{dt^2} = - q \frac{\partial}{\partial x^j} V[/itex]
1. What is the difference between contravariant and covariant vectors in the context of electric fields?
Contravariant and covariant vectors refer to two different ways of representing vectors in three-dimensional space. In the context of electric fields, a contravariant vector represents the direction and magnitude of the electric field, while a covariant vector represents the rate of change of the electric field in a particular direction. Essentially, contravariant vectors describe the electric field itself, while covariant vectors describe how the electric field changes in different directions.
2. How are contravariant and covariant vectors related to each other in the context of electric fields?
In the context of electric fields, contravariant and covariant vectors are related by the metric tensor, which is a mathematical object that relates the two types of vectors. The metric tensor allows us to convert between contravariant and covariant vectors, allowing us to describe the electric field in different ways.
3. What is the significance of contravariant and covariant vectors in understanding electric fields?
Contravariant and covariant vectors are important in understanding electric fields because they provide us with two different perspectives on the same physical phenomenon. By using both types of vectors, we can gain a more complete understanding of the electric field and how it behaves in different directions.
4. How are contravariant and covariant vectors used in practical applications of electric fields?
In practical applications, contravariant and covariant vectors are used to calculate the electric field at a given point in space. By using both types of vectors, we can determine the direction and magnitude of the electric field at that point, as well as how it changes in different directions.
5. Are contravariant and covariant vectors only applicable to electric fields?
No, contravariant and covariant vectors are mathematical concepts that can be applied to many different physical phenomena, including electric fields. They are used in a variety of fields such as physics, engineering, and mathematics to represent and analyze vectors in three-dimensional space.
  • General Math
