Contrapositive Proof of Theorem: x > y → x > y+ε
This does not contradict the fact that for any e<0 the implication is also true.Homework Statement Theorem: Let x,y,ε be ℝ. If x≤ y+ε for every ε > 0 then x ≤ y.Write the above as a logic statement and prove it using contrapositive proof.In summary, the theorem states that if x is always less than or equal to y plus any positive epsilon, then x is less than or equal to y. To prove this, we can use the contrapositive statement x > y → x > y+ε, which can be rewritten as x > y → x-y > ε. We can then choose any positive ε, such as ε = x-y
trebolian
The attempt at a solution
The contrapositive statement x > y → x > y+ε is only true if ε < 0. Does a contrapositive proof negate the equality of ε?
It should. The negation of x≤ y+ε  for every ε > 0 requires X>y+e for some e<0.
Write the above as a logic statement and prove it using contrapositive proof.The attempt at a solution
I don't know what you mean by "the equality of [itex]\epsilon[/itex]". Are you referring to the in equality "[itex]\epsilon> 0[/itex]"?
In any case your first statement is incorrect. If x> y then there exist an infinite number of positive [itex]\epsilon[/itex] such that [itex]x> y+ \epsilon[/itex]. x> y implies x-y> 0. Take [itex]\epsilon[/itex] to be any positive number less than x- y.
HallsofIvy, are you saying that the contrapositive of "for every ε > 0..." is actually "there exists an ε > 0 such that..."?
I would have thought that the contrapositive should be "there exists an ε < 0 such that...", i.e switch the inequality as well as the universal/existential quantifier
you can't negate saying that you need an epsilon greater than zero. The negation must be done looking for some nonnegative epsilon. Any will do it, in particular epsilon=y-x.
A mistake in my previous post. Indeed, to prove ~Q implies ~P you have to show that for some e>0, x > y → x > y+ε, since negating Q means that there is at least one e>0 such that ~Q is true.
What is a contrapositive proof?
A contrapositive proof is a type of mathematical proof that involves proving the truth of a statement by showing that its negation is false. This is done by assuming the negation of the statement and then using logical reasoning to show that it leads to a contradiction.
What does x > y → x > y+ε mean?
This notation means that if x is greater than y, then x will also be greater than y+ε, where ε is a positive number representing a small amount of increase. Essentially, this theorem is stating that if x is greater than y, then x will also be greater than a value slightly larger than y.
Why is a contrapositive proof useful?
A contrapositive proof can be useful in situations where it is difficult to prove a statement directly. By proving the negation of the statement, one can indirectly show the truth of the original statement. This type of proof can also provide a different perspective and help to deepen understanding of a mathematical concept.
What are the steps to conducting a contrapositive proof?
The steps to conducting a contrapositive proof are as follows: 1) Assume the negation of the statement, 2) Use logical reasoning to show that this leads to a contradiction, 3) Conclude that the negation of the statement must be false, and therefore, the original statement is true.
Can a contrapositive proof be used for all types of statements?
No, a contrapositive proof can only be used for conditional statements of the form "if A, then B". It cannot be used for other types of statements such as biconditional statements or existential statements.
Changing the Statement Combinatorial proofs & Contraposition
  • Math Proof Training and Practice
9K
