Control volume flux problem
  1. Sep 5, 2010 #1
    The velocity components of a flow are given by:
    u=-x v=y
    Compute the volume of fluid flowing per unit time per unit area through a small surface at (1,2) whose normal makes an angle of 60 deg with the positive x-axis.
    2. Relevant equations
    V= u i + y j (velocity vector)
    dq = V dot n dS (volume efflux)
    3. The attempt at a solution
    So for this problem V = -1 i + 2 j
    then dq/dS = Vcos(60) = -cos(60) i + 2cos(60) j
    i believe it wants the magnitude of dq/dS which is where i get confused.
    is the magnitude this:
    magnitude dq/dS = sqrt((-.5)^2 + (1)^2)
    or is it this:
    magnitude dq/dS = sqrt(-(.5^2) + (1^2))
  3. Sep 5, 2010 #2
    hunt_mat
    You have to compute the unit normal vector and take the dot product of this nornal with the velocity vector field.
    You know that the surface is at 60 degrees from the positive x-axis. can you compute a normal from there?
  4. Sep 5, 2010 #3
    would the normal vector be...
    n = cos(60) i + sin(60) j
    so then...
    dq/dS = V dot n = -cos(60) i + 2sin(60) j
    and...
    magnitude of dq/dS = sqrt( (-cos(60))^2 + (2sin(60))^2)
  5. Sep 6, 2010 #4
    hunt_mat
    Almost, the dot product of 2 vectors is a scalar, so:
    [tex]
    \frac{dq}{dS}=\mathbf{V}\cdot\hat{\mathbf{n}}=u\cos \Bigg(\frac{\pi}{3}\Bigg) +v\sin \Bigg(\frac{\pi}{3}\Bigg)
    [/tex]
Similar Discussions: Control volume flux problem
  1. Flux problem (Replies: 1)
  2. Flux problem (Replies: 3)
  3. Flux problem (Replies: 1)
  4. Flux Problem (Replies: 5)
  5. Volume Problem (Replies: 4)
Loading...
