Waquas Mehmood
- 5
How can we control an SCR through a microprocessor with an opto coupler used as an 'isolating and amplification' device between the microprocessor and the SCR.
An SCR, or silicon-controlled rectifier, is a type of semiconductor device used for controlling high power electrical currents. It acts as a switch, allowing current to flow when triggered by a small control signal.
A microprocessor is a small electronic device that contains a central processing unit (CPU) and other components necessary for processing data and carrying out instructions. It is the "brain" of a computer or electronic system.
An opto coupler, also known as an optocoupler or photocoupler, is an electronic component that transmits electrical signals between two isolated circuits using light. It provides electrical isolation and can be used for signal amplification and noise reduction.
The microprocessor sends a control signal to the opto coupler, which then transmits a light signal to the SCR. This light signal triggers the SCR to turn on or off, allowing the microprocessor to control the flow of current through the device.
Using a microprocessor allows for precise and flexible control of the SCR. It also allows for remote control and monitoring, as well as the ability to program and automate the operation of the SCR. Additionally, the use of an opto coupler provides electrical isolation, which can improve safety and reduce interference from other electrical components.
