Converge/Diverge: Summation 1 to ∞ (2*4*6*8*...*(2n)) / (n!)
  • Thread starter meson0731
For some reason I thought it was \lim_{n \to \infty}\frac{2n+2}{2n} = 2 + \lim_{n \to \infty}\frac{2}{2n} = 2 and was really confused. I should know better than to do math late at night lol. Thanks for catching that!In summary, the sum \sum_{n=1}^{\infty}\frac{2^n n!}{n!} converges to 2, which was found using the ratio test. However, the limit was incorrectly calculated in the original attempt, but was later corrected to 1 by another user.
meson0731
summation 1 to infinity (2*4*6*8*...*(2n)) / (n!)
I'm a little confused on the "..." part... I used the ratio test and the numbers obviously cancel out, but I am not sure if the (2n+2)/(2n) part cancel out to just make (2n+2) on the top. This would make the limit equal to 2 and it would diverge. But I am not entirely sure if that's right...
It looks like you want to know if the following sum converges or diverges:
[tex]\sum_{n=1}^{\infty}\frac{2^n n!}{n!}=\sum_{n=1}^{\infty}2^n[/tex]
That should be pretty easy.
I don't see how you rewrote it like that. Would my method of using the ratio test work? And if so how exactly would the top partion cancel out.
Try thinking about it. The ratio test works but is overkill for this problem.
The ratio test works, but you messed up calculating it. (Hint: The ratio is 2).
You said you were confused about the "..." part, so I just thought that I would mention that the [itex]n^{th}[/itex] term in the sum is [itex](2*4*\cdots*(2n))/n![/itex].
Perhaps you knew this, but since you said you were confused by the "..." and jgens simplification, I thought you might be overlooking this.
When i did the ratio test i did get 2 for the limit. Does this mean that I did it right?
Depends. In the OP you wrote something about [itex]\lim_{n \to \infty}\frac{2n+2}{2n} = 2[/itex]. In this case the limit is correct but the ratio is not. You should get [itex]\lim_{n \to \infty} 2 = 2[/itex].
I just realized that I wrote it wrong :rolleyes: . I got lim as x > infinity of (2n+2)/(n+1) which is 2.
Then you solved the problem correctly :)
Wait, what? The limit doesn't look right to me...
[tex]\lim_{n \to \infty}\frac{2n+2}{2n} = \lim_{n \to \infty}\frac{2n}{2n} + \lim_{n \to \infty}\frac{2}{2n} = 1 + \lim_{n \to \infty}\frac{1}{n} = 1[/tex]
Right?
Right?
Yep. My bad.
1. What is the formula for the sum of the series 2*4*6*8*...*(2n) / (n!)?
The formula for the sum of this series is ∑ (2n) / (n!), where n starts at 1 and goes to infinity.
2. What is the convergence or divergence of this series?
This series is a divergent series, meaning that the sum of the series does not have a finite value.
3. How do you calculate the partial sum of this series?
The partial sum can be calculated by plugging in a specific value for n in the formula ∑ (2n) / (n!). For example, the partial sum for n = 5 would be 2*4*6*8*10 / 5! = 3.2.
4. What is the significance of the factorial in the denominator of the formula?
The factorial in the denominator is used to account for the increasing denominator in each term of the series. This ensures that the series does not approach infinity as n increases.
5. Can this series be used in real-life applications?
Yes, this series can be used in various mathematical and scientific calculations, such as probability and statistics, to determine the likelihood of certain events occurring.
