Homework Help: Convergence of 1/K!
  1. Apr 15, 2015 #1
    Does (1/(k!)) converge?
    2. Relevant equations
    Convergence Tests?
    3. The attempt at a solution
    I thought I could just simply use the divergence test, but I'm not sure if that only tells you if it's divergent and not whether it is convergent or not.
    lim(k>inf) (1/(k!)) = 0, if L =/= 0, then it is divergent, but since it is 0 does that make it convergent, or inconclusive?
    I've thought about trying a comparison test but I'm not sure what I could compare 1/k! too, would I compare it to 1/k? In which case it would be divergent.
    Kinda stuck here on which to use.
  3. Apr 15, 2015 #2
    Are you wondering about the convergence of the series ##\Sigma_{k=0}^\infty \frac{1}{k!}##
    We can set ##e^x=\Sigma_{k=0}^\infty \frac{x^k}{k!}##. Then ##e^1=\Sigma_{k=0}^\infty \frac{1^k}{k!}=\Sigma_{k=0}^\infty \frac{1}{k!}##
    So, the series converges and equals ##e##.
  4. Apr 15, 2015 #3
    HallsofIvy
    While it is true that [itex]\sum \frac{1}{k!}[/itex] converges to e, if you did not know that initially, you could have used the "ratio test": [itex]\sum a_n[/itex] converges if [itex]\frac{a_{n+1}}{a_n}< 1[/itex] and diverges if it is greater than one.
    (Your test, that if [itex]\sum a_n[/itex] converges, the [itex]a_n[/itex], must go to 0, is generally called the "divergence test" since it tells us that if that limit is NOT 0 then the series diverges but does NOT tell us one way or the other if the limit is 0.)
  5. Apr 15, 2015 #4
    phyzguy
    I don't think you stated the ratio test quite right. The ratio test tells us that the series converges if [itex]lim_{n->\infty} \frac{a_{n+1}}{a_n} <1[/itex]. The series the OP asked about certainly passes this test, since [itex]lim_{n->\infty} \frac{n!}{(n+1)!} = lim_{n->\infty} \frac{1}{n+1} = 0[/itex]. You wrote that the ratio test is that the series converges if [itex]\frac{a_{n+1}}{a_n} < 1[/itex]. The series [itex]\sum_{n=1}^\infty \frac{1}{n} [/itex] would pass this test since [itex]\frac{a_{n+1}}{a_n} = \frac{n}{n+1} < 1[/itex] for all n, but it does not converge. The ratio test for this series gives [itex]lim_{n->\infty} \frac{a_{n+1}}{a_n} = lim_{n->\infty} \frac{n}{n+1} = 1[/itex]
Have something to add?
Draft saved Draft deleted
Loading...
