Homework Help: Convergence of a series
  1. Dec 15, 2012 #1
    Use the limit comparison test to determine whether the following series converges or diverges.
    [itex]\sum{\frac{2^n}{3^n - 1}}[/itex]
    Where the sum is from n = 1 to n = ∞.
    2. Relevant equations
    The limit comparison test:
    Suppose an>0 and bn>0 for all n. If the limit of an/bn=c, where c>0, then the two series [itex]\sum{a_{n}}[/itex] and [itex]\sum{b_{n}}[/itex] either both converge or both diverge.
    3. The attempt at a solution
    So I get that the point is to find another series that you know diverges or converges that will also make the above limit easy to evaluate. All I can think to do is to compare it to something like [itex]\sum{1/3^n}[/itex] or [itex]\sum{2^n}[/itex], the first of which results in the limit not existing and the second of which results in the limit being zero. I think it's obvious that the series should converge, as the denominator is always equal to or greater than the numerator. But I'm out of ideas on what other sums I could use in the limit comparison test.
  3. Dec 15, 2012 #2
    Compare it to
    [tex]\sum \frac{2^n}{3^n}[/tex]
    [tex]\frac{2^n}{3^n}\cdot\frac{3^n-1}{2^n}[/tex]
    [tex]\frac{3^n}{3^n} - \frac{1}{3^n}[/tex]
    [tex]1- \frac{1}{3^n}[/tex]
    With limit n->infinity, this = 1
  4. Dec 15, 2012 #3
    sharks
    Not quite, although the limit of the ratio is equal to 1. There are a few mistakes, in my opinion:
    First, the ratio is wrong. It should be ##u_n/v_n## or in the OP's equation ##a_n/b_n##. You've done the opposite. (A condition is missing in this case: c<∞)
    Second, the limit is obtained using L'Hopital's rule.
    Third, [itex]\sum_{n=1}^{\infty} \frac{2^n}{3^n}[/itex] is in fact a geometric series.
    It should be easy now to form the final conclusion.
  5. Dec 15, 2012 #4
    Doh! That should've been my next try. I got too caught up trying to do the same thing I was doing for the preceding questions. Thanks for the help guys :)
