Homework Help: Converging Sequnces
  1. Jun 5, 2012 #1
    Determine whether each of the following sequences converge or not. In each case present a formal
    explanation. If a sequence converges find the limit and if not determine whether there should be any
    converging subsequences, and if so find more than one converging subsequences.
    Xk+1 = (k/k+2)Xk, where X1 = 1/2
    Attempt: Now I was thinking of taking the (lim k-->∞ 1/(1+2/k) ) (lim k-->∞ Xk). In other words take the limits of the individual sequences and show that they converge, but I'm realizing I don't have an expression for Xk so I might not be able to do this. In the same breath if this sequence doesn't converge, would finding two subseqeunces through by fiddling with some numbers work?
  3. Jun 5, 2012 #2
    tiny-tim
    hi trap101! :smile:
    xk/x1 = … ? :wink:
  4. Jun 5, 2012 #3
    Ray Vickson
    As written, your sequence is xk+1 = 3xk, because k/k + 2 = 3. Is that what you were really given?
    RGV
  5. Jun 5, 2012 #4
    [k/(k+2)] Xk ......so the fraction k/(k+2) times Xk
    .man I need to learn latex.......
  6. Jun 6, 2012 #5
    Ray Vickson
    No. Just use parentheses, as you did above.
    Anyway, the easiest way to deal with the question is to find an actual formula for xk. If you write out in detail the first few values of xk you will see a pattern, and can then prove the general result by induction, for example.
    RGV
