Converting km/hr to m/s^2: What is the Formula?
  • Thread starter ATranPV
  • Tags
    Convert
In summary, the conversation was about converting 83km/hr to m/s^2. The attempt at a solution was provided, but there was confusion about whether the conversion was meant to be for speed or velocity. Ultimately, it was determined that the question may have been a typo and the correct answer was m/s, not m/s^2.
ATranPV
Convert 83km/hr to m/s^2
Simple I know...but I still can't figure it out
83km/hr(10^3m/km)(1hr/60min)(1min/60sec)
The units cancel however leaving me with m/s not with m/s^2.
The seconds^2 is what I cannot figure out.
Thanks in advance!
You can't convert km/hr to m/s^2.
83 km/hr is not acceleration, it is a speed. Your answer is right. Are you sure that is what they want?
Yah, m/s^2 is an acceleration, km/hr is a velocity. Must be a typo
Peng, isn't it supposed to be speed instead of velocity? Velocity has a specified direction.
Really? Must be a typo then...good to know that I'm not missing something obvious!
Sigh...
Doesn't matter. Don't troll.
Pengwuino said:
Sigh...
Shame on you peng :frown:
I'll have a field day on this tomorrow on chat :biggrin:
1. How do I convert kilometers per hour to meters per second squared?
To convert km/hr to m/s^2, you need to use the formula m/s^2 = (km/hr * 1000) / (3600)^2. This will give you the acceleration in meters per second squared.
2. Why do we need to convert km/hr to m/s^2?
Kilometers per hour (km/hr) is a unit of speed, while meters per second squared (m/s^2) is a unit of acceleration. We may need to convert between these units when working with physics or engineering problems that involve acceleration.
3. What is the conversion factor for km/hr to m/s^2?
The conversion factor for km/hr to m/s^2 is (km/hr * 1000) / (3600)^2. This takes into account the different units of measurement and converts speed to acceleration.
4. Can I use a calculator to convert km/hr to m/s^2?
Yes, you can use a calculator to convert km/hr to m/s^2 by using the formula m/s^2 = (km/hr * 1000) / (3600)^2. You can also find online converters or use a spreadsheet program to make the conversion.
5. Is there a difference between km/hr and m/s^2?
Yes, there is a difference between km/hr and m/s^2. Km/hr is a unit of speed, while m/s^2 is a unit of acceleration. This means that km/hr measures how fast an object is moving, while m/s^2 measures the rate at which an object's velocity is changing.
