Converting Sigma notation
  • Thread starter Saitama
  • #51
3,816
92
You had to subtract the k=0 term, which ended up being just "x".
I don't see it back in your integrated result.
Let me explain with an example.
Suppose you have the function f(x)=x2 + 3
Now you know that f(0)=3 don't you?
Taking the derivative we get f'(x)=2x.
Taking the integral again we get [itex]\int f'(x)dx = x2 + C[/itex]
(This is called an indefinite integral, since the boundaries were not given.)
As you can see the result is not equal to the original function - we lost the '3' in the process.
But since we know that f(0)=3, we can deduce that the integration constant C must be 3.
In which step should i substitute zero to get the constant? :confused:
  • #52
I like Serena
6,579
176
I'm assuming you mean in my example.
(It's slightly different for the current problem.)
In my example we have as input [itex]f(x) = \int f'(x) dx = x^2 + C[/itex] and f(0)=3.
We want to find f(x).
Filling in x=0 gives: [itex]f(0) = 0^2 + C = 3[/itex].
So C = 3.
  • #53
3,816
92
So C = 3.
I got what you said. :smile:
But i am asking in which step should i put x=0?
Should i put x=0 during the integration step? :confused:
  • #54
I like Serena
6,579
176
I don't understand your question.
Afaik I have explicitly stated where you put x=0.
I only could have added as a last step that the conclusion is that f(x)=x2 + 3.
  • #55
3,816
92
i think the constant is zero. :confused:
  • #56
I like Serena
6,579
176
Now I really don't understand you. :confused:
Which constant?
In which formula?
In which post?
Why would it be zero?
  • #57
3,816
92
Which constant?
In which formula?
In which post?
You gave an example that f(x)=x2+3.
And you said that f(0)=3, i.e you substituted the value 0 at the place of x. Right..?
Now that 3 is our integration constant, we can substitute 3 in [itex]\int f'(x)=x^2+C[/itex] at the place of C.
I did the same in my question. I substituted 0 in f(x), i.e i substituted 0 in:-
[tex]f(x)=\sum_{k=1}^n \frac{{}^nC_k}{k+2}x^{k+2}[/tex]
So i got f(0)=0. Therefore integration constant is 0.
Did you get me now? :confused:
  • #58
I like Serena
6,579
176
Yes, I more or less get what you did, but it is not right.
Let's take it a couple of steps back.
You had:
[itex]f'(x) = x(x+1)^n \color{red}{\textbf{- x}}[/itex]
You integrated this wonderfully, but you forgot the "[itex]\color{red}{\textbf{- x}}[/itex]" I just marked.
So you should have:
[tex]f(x) = \int f'(x)dx =\frac{x(x+1)^{n+1}}{n+1}-\frac{(x+1)^{n+2}}{(n+1)(n+2)} - \frac {x^2} 2 + C[/tex]
Now you need to determine the integration constant C using f(0) = 0, but C is not zero!
  • #59
3,816
92
You had:
So you should have:
So then what's the C, i don't seem to find any other way to find C. :confused:
  • #60
I like Serena
6,579
176
What do you get if you fill in x=0 in this formula?
[tex]f(x) = \frac{x(x+1)^{n+1}}{n+1}-\frac{(x+1)^{n+2}}{(n+1)(n+2)} - \frac {x^2} 2 + C[/tex]
  • #61
3,816
92
If i would fill x=0 in this formula i get
[tex]f(x) = \frac{0^{n+2}}{n+1}-\frac{0^{n+2}}{(n+1)(n+2)}+ C[/tex]
Is it correct..?
  • #62
I like Serena
6,579
176
Noooo. ;)
You need to fix the second term.
  • #63
3,816
92
Noooo. ;)
Ok fixed. :smile:
[tex]f(x) =-\frac{1^{n+2}}{(n+1)(n+2)}+ C[/tex]
Is it ok..?
  • #64
I like Serena
6,579
176
Yes..... :smile:
  • #66
I like Serena
6,579
176
But now what's the C?
Set the expression equal to zero (since we had f(0)=0) and solve C.
  • #67
3,816
92
I set it to 0 and i get
[tex]C=\frac{1^{n+2}}{(n+1)(n+2)}[/tex]
So therefore our final answer is:-
[tex]f(x)=\frac{x(x+1)^{n+1}}{n+1}-\frac{(x+1)^{n+2}}{(n+1)(n+2)} - \frac {x^2} 2 + \frac{1^{n+2}}{(n+1)(n+2)}[/tex]
Substituting x=1, i get
[tex]f(1)=\frac{n.2^{n+2}-n^2-3n-4}{2(n+1)(n+2)}[/tex]
Is it right..?
Can i simplify it further?
  • #68
I like Serena
6,579
176
Is it right..?
You're expression for f(x) is right! :smile:
However your simplification after substitution of x=1 is wrong. :(
You can check by for instance filling in n=1.
(What should the result be for n=1 and for n=2? And does your expression match it?)
And actually I would recommend simplifying as little as possible.
Simplify the obvious things.
But do not try to simplify too much, since it opens up the door to mistakes.
And especially if the resulting expression is not really simpler, it's not worthwhile anyway.
  • #69
3,816
92
Thanks, i would correct it. :smile:
So now we are done with this question, Right..?
  • #70
I like Serena
6,579
176
Hmm, you still didn't give the right answer.... :uhh:
But if you substitute x=1 without simplifying it, that would be a proper answer, so I guess we're done, with only a technicality left. :smile:
Related Threads on Converting Sigma notation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
