Exploring the Relationship Between Convex Lenses and Objects
In summary, a convex lens will have an image that decreases in distance from the object as the lens moves further away from the object. The image will reach its minimum distance from the object when the lens is at its farthest point from the object.
fromthepast
34
I did an experiment with a convex lens, object, and image. As the lens moved farther and farther away from the object, the image decreased its distance (to remain in focus) from the object as well up to a certain point. After that point, as the lens increased its distance from the object, the image had to increase its distance from the object as well to keep in focus.
Why is this?
N/A
It's a theoretical question with no exact solution.
Why is this?
N/A
One could say that it happens that way because that is the way a lens behaves.
The mathematical summaries of the situations with a lens [the lens formulae] indicate this behaviour - especially if you look at the right formula.
What lens formulae do you know?
1/f = 1/s + 1/s'
m = h'/h = -s'/s
Does it have something to do with the focal point?
fromthepast said:
1/f = 1/s + 1/s'
m = h'/h = -s'/s
I would like to say yes to that.
Do you know the formula using the distances from the focal points rather than from the lens?
Both the object distance and the image distance are measured from the lens. The object and the real image are at opposite sides of the lens, so the object and the image are d=s+s' distance from each other. The image distance is s'=d-s. Plug in for s' into the lens equation, and find d in terms of the object distance s. Investigate the function, plot it. You will see, it has a minimum.
ehild
1. What is a convex lens?
A convex lens is a type of lens that is thicker in the middle and thinner at the edges. It is curved on both sides and causes light rays to converge towards a focal point, creating a magnified and inverted image.
2. How does a convex lens affect the objects placed in front of it?
A convex lens can magnify or reduce the size of an object, depending on its distance from the lens. Objects placed farther away will appear smaller, while objects placed closer will appear larger.
3. What factors affect the relationship between convex lenses and objects?
The distance between the object and the lens, the shape of the lens, and the refractive index of the lens material all play a role in the relationship between convex lenses and objects.
4. How does the shape of a convex lens affect its properties?
The curvature of a convex lens determines its focal length, which in turn affects the magnification and image formation. A steeper curvature leads to a shorter focal length and a more magnified image.
5. How is the relationship between convex lenses and objects used in everyday life?
Convex lenses are used in various applications, such as eyeglasses, cameras, and microscopes. They are also used in telescopes to magnify distant objects and in binoculars to provide a wider field of view.
