Coordinate change and gravity
  • I
  • Thread starter jk22
Main Question or Discussion Point
What I understood is that The Schwazschild metric is obtained by setting spherical symmetry in the metric and solves the field equation in vacuum.
But is the flat metric a solution too, or does it mean that changing the coordinates induces gravity ?
Answers and Replies
martinbn
558
The Schwarzschild solution is not a single solution. It is in fact a one parameter family of solutions. If the parameter M is zero you get the Minkowski solution.
6,060
If you set M to 0 then you get a flat metric. All of the curvature goes to zero. So there is no gravity induced, it is just spherical coordinates in flat spacetime.
Nugatory
Mentor
12,830
5,454
The Einstein field equations are differential equations, so they have multiple solutions depending on the boundary conditions that we choose. The solution will be a metric tensor that solves the field equations consistent with the particular boundary conditions we've chosen; it determines a particular spacetime geometry.
Flat spacetime is the geometry we get when we choose empty space everywhere as the boundary condition. We can write this solution in many different coordinate systems; for example Minkowski ##ds^2=-dt^2+dx^2+dy^2+dz^2## and polar ##ds^2=-dt^2+dr^2+r^2(d\theta^2+\sin^2\theta{d}\phi^2)## are two different ways of writing the metric tensor for flat spacetime. No matter what coordinates we choose, the curvature tensors will come out zero, there will be no gravity.
Schwarzschild spacetime is another geometry, the one we get when we choose a spherically symmetric mass distribution as the solution. Again, we can write the metric tensor for that spacetime in many different coordinate systems: Schwarzschild coordinates (of course, and it is unfortunate that we use his name both for the spacetime he discovered and for the coordinates he used to describe it - they're different things), or Kruskal, or Painleve, or .... but no matter which we choose, the gravitational effects calculated from the curvature tensors will be the same.
Other choices for the distribution of stress energy yield yet other spacetimes. Again, the gravitational effects in different spacetimes will be different, but they won't change with our choice of coordinates.
jbriggs444
2019 Award
8,892
3,637
Am I missing something? I would interpret "empty space everywhere" to mean that you are looking for vacuum solutions. But flat space-time is not the only vacuum solution.
Nugatory
Mentor
12,830
5,454
Not missing anything, I'm just being a bit careless about the wording around a non-critical point.
Likes jbriggs444
Related Threads on Coordinate change and gravity
  • Last Post
