Coordinate matters
I was wondering, if a metric known to be a solution of Eintein field equation can be a static or expanding spacetime depending on a change of coordinates, what does this tells us about that metric? Can it be physical?
I mean in the sense that it is usually said that to check if something is phyisical or the result of a coordinate peculiarity the best way is to see whether that property changes with a change of coordinates, for instance like it is often done to see if a singularity is physical or can be made to go away by a change of coordinates.
To be more specific I was thinking of de Sitter's and Milne's models. They share the property that both are empty universes, wich maybe is giving us the clue that empty universes are not physical?
Answers and Replies
Bill_K
Insights Author
4,157
201
If peculiar coordinate systems meant the solution itself was unphysical that would rule out the Schwarzschild solution.
I don't understand this. The Schwarzschild solution is a vacuum solution, in which Riemannian curvature doesn't vanish (only Ricci curvature), not exactly the same as an "empty" universe solution in which Riemannian curvature vanishes and therefore is a flat spacetime.
So I don't know in what sense you think it has a peculiar coordinate system. Schwarzschild solution is static under any coordinate transformation, in the OP I referred specifically to solutions that can switch from static to expanding with a coordinate transformation.
AFAIK the vacuum is something physical.
JesseM
Not a "static or expanding spacetime" but a static or expanding space. The way that the shape of space changes dynamically over time depends entirely on your choice of simultaneity convention (slicing the spacetime into a series of spacelike surfaces in different ways). Once you have a simultaneity convention, for each spacelike surface you can calculate the frame-invariant proper distance along spacelike curves confined entirely to that surface, and use that to construct an http://www.bun.kyoto-u.ac.jp/~suchii/embed.diag.html [Broken], and for each surface (represented by a dotted curve on the Kruskal-Szekeres diagram) there's a corresponding embedding diagram on the right:
It's exactly the same with the expanding Milne universe--because you are choosing a different simultaneity convention than the one in any inertial frame, the embedding diagram of a spacelike surface of simultaneity looks different (the spatial curvature in each surface is different), but the spacetime curvature is flat either way. From Ned Wright's cosmology tutorial, here's a diagram showing surfaces of simultaneity in the Milne universe (gray curves) as well as lines of constant cosmoving position (black line), when plotted in an ordinary Minkowski diagram where the horizontal axis is a surface of constant time in an inertial frame, and the vertical axis is a line of constant position in the inertial frame:
Bill_K
Insights Author
4,157
201
Take a look at Novikov coordinates, in which the Schwarzschild solution is time-dependent. Discussed in MTW on p.826.
Thanks for your nice explanation.
But actually I'm referring to spacetimes not to the spatial spacelike surface.
So I'm actually asking about "static spacetimes" (basically a space-time is static if it admits a hypersurface orthogonal timelike Killing vector field) like Schwarzschild or Minkowski, versus "non-static spacetimes" like those called "expanding":e.g. our universe (even if in these what expands is only the space).
The way you explain it makes it seem like expansion is a coordinate property of the spacelike surfaces that can go away with a coordinate transformation.
In fact, at least for Minkowski and de Sitter models , looks like even though they are static spacetimes they can acquire "expansion" (FRW versions of Minkowski (Milne) and de Sitter) thru a coordinate transformation.
JesseM
But under that definition an empty Milne universe is a static spacetime, no? It "admits a hypersurface orthogonal to the timelike Killing vector field" even if that hypersurface doesn't happen to be one of the hypersurfaces of simultaneity in the cosmological coordinate system used to describe the Milne universe (instead it could just be a hypersurface of simultaneity in an inertial frame in the same spacetime).
But the "expansion" in this case wouldn't be a matter of making them non-static as I understand it, it would just be a property of one particular set of spacelike hypersurfaces.
Absolutely, that is my point.
Exactly, That is what I'm saying, they are still static spacetimes and yet they can have that "expanding" property with the right coordinates, isn't that odd?
I mean compare with the way a coordinate property (like a coordinate singularity) is usually treated.
JesseM
Well, it doesn't really seem odder to me than the relativity of simultaneity itself.
I suppose coordinate singularities are treated in a "dismissive" way precisely because in the past some authors thought they were real and some work had to be done to show this was a mistake, while there isn't really an analogous type of mistake that needs correcting in the case of expanding space. And you can also say that while simultaneity is coordinate-dependent and therefore arbitrary, once you have fixed a simultaneity convention, the notion of "distance" in any given hypersurface of simultaneity does have a coordinate-independent meaning in terms of proper distance along spacelike curves confined to that hypersurface.
If one intuitevely understands Lorentz transformations, I can see nothing odd in the relativity of simultaneity. In any case I don't see the relation between this SR concept and what I'm trying to clarify.
But what "authors think should be real" is not a very rigorous way to solve things in mathematical physics, is it?
I mean that if a mathematical argument can be used to dismiss a singularity due to its coordinate dependance regardless what authors in general may prefer, why is this argument not valid to dismiss another coordinate property?
Consider Milne universe, according to its scale factor, radiation in this universe should undergo cosmological redshift. And yet we know this universe is a patch of static Minkowski spacetime, and static spacetimes by definition can't have cosmological redshift.
So is cosmological redshift in this universe a spurious coordinate property and there is really no redshift? Or alternatively we must admit that static spacetimes can have cosmological redshift?
In the Milne universe, radiation undergoes redshift because an "inertial" observer (what I really mean is an observer with constant spatial coordinates) in this universe is accelerating, which is (after the Einstein equivalence principle) equivalent to a gravitational field in what is seen and felt by observers. So this observer sees redshift because he himself is accelerating through spacetime, not because spacetime is expanding per se.
BTW, de Sitter spacetime isn't globally static. There is the so-called static coordinate patch, but this doesn't cover the whole de Sitter spacetime. Just like the Milne universe doesn't cover the whole Minkowski spacetime.
When you want to discuss things like "Is something physical?" _and_ have to use coordinate systems, it's best to use global ones. In the right coordinates, the Schwarzschild spacetime has no interior, so there is no black hole. But that's just because those coordinates aren't global.
... if a mathematical argument can be used to dismiss a singularity due to its coordinate dependance... why is this argument not valid to dismiss another coordinate property?
Coordinate singularities aren't "dismissed", they are simply recognized for what they are. What we "dismiss" is the erroneous belief that a coordinate singularity must represent a singularity of the manifold, such as singular intrinsic curvature. (By the way, this isn't a "mathematical argument", it is a physical argument; the application of coordinates to physical entities involves physical reasoning.)
Consider Milne universe, according to its scale factor, radiation in this universe should undergo cosmological redshift. And yet we know this universe is a patch of static Minkowski spacetime, and static spacetimes by definition can't have cosmological redshift. So is cosmological redshift in this universe a spurious coordinate property and there is really no redshift? Or alternatively we must admit that static spacetimes can have cosmological redshift?
You're confused. Redshift is a coordinate independent prediction of any given model, and nothing you've said conflicts with this fact. The "Milne universe" supposes that all substance originated at a single event in Minkowski spacetime, and is expanding outward from that event, with speeds distributed in a Lorentz-invariant way. On this basis we would expect each straight worldline emanating from the origin event to be receiving redshifted light from the surrounding (finite and spatially expanding) cloud of particles. On the other hand, we can describe this "universe" in terms of a curved spatial foliations, so that it is of infinite spatial extent with constant negative spatial curvature, we again find exactly the same predicted red shift.
It doesn't matter what coordinate system we use to evaluate a situation, the invariant predictions (like observed redshift) come out the same, because the choice of coordinates doesn't affect physically invariant things.
lol
Oh, this is ok with me but doesn't have anything to do with my post and my questions. Do you consider Milne universe (a patch of Minkowski spacetime) as a static spacetime or not?
Since the Milne universe is a patch of the static Minkowski spacetime, it must be static also, as I said before. However, it's not geodesically complete, that's one thing.
The second thing is that an observer "at rest" in the Milne universe (i.e. constant spatial coordinates) is accelerated, and so sees an apparent redshift. That's the second thing. (See p.ex. http://iopscience.iop.org/0264-9381/16/10/323/pdf/0264-9381_16_10_323.pdf or http://prd.aps.org/abstract/PRD/v55/i10/p6061_1)
This redshift is real in the sense that such a observer sees it, but its origin is a simple Doppler effect and not the expansion of spacetime per se.
Thanks, earl_gray, I found your posts very informative and to the point.
Some details that I think are worth clarifying further:
I agree on the mechanism of redshift (Doppler) in the Milne model, we actually only know two basic mechanisms of redshift anyway: gravitational and Doppler. In FRW cosmology, the cosmological redshift mechanism depends on the coordinates chosen and here at PF there have been endless discussions about whether it was Doppler, Gravitational or a mixture of the two depending on what coordinate system is used and the state of motion of the observers.
That said my point was that in the Milne model that you have stated in your post is a static spacetime, an observer sees a "cosmological redshift" (whatever the mechanism), the distinction of apparent versus real doesn't apply to the redshift since it is a simple measure.
So we have a static model that has both cosmological redshift, and "aparent" expansion, in this case the term apparent does apply since the expansion in this model is a coordinate effect in a static spacetime and expansion is not directly measurable as redshift is.
It is usually stated that static spacetimes can't have cosmological redshift (regardless of the mechanism of production of the redshift), is the Milne universe some kind of exception to this rule?
I also completely agree with you that when discussing the "physicality of something" one must consider it from the global coordinate system to get the maximally extended manifold.
One could argue that Doppler redshift is no "real" redshift, but I don't think that discussion is necessary. And gravitational redshift can have two causes: the expansion of spacetime or the "climbing out" from a static mass source in a static background. Both should be distinguished in a detailed discussion.
I haven't seen this claim before, but I also didn't do much cosmology. Maybe it was meant that in a static universe, if the observer's four-velocity agrees (to within a factor) with the Killing vector of stationarity, then there is no redshift, which would exclude the Milne universe. Maybe one has to substitute "geodesically complete static spacetime", which also would exclude the Milne universe. Do you have a source for this statement?
spcetime expansion is not usually considered a cause of gravitational redshift in standard cosmology, it is considered the cause of "cosmological redshift". The specific mechanism (Doppler, Gravitational or both, depends on coordinates choices as I said.
Well, it's a consequence of attributing cosmological redshift to expansion.
Maybe those reasons exclude Milne universe from the general claim.
So it would be interesting to know if the general claim "static spacetimes can't have cosmological redshift" is an accurate statement according to current cosmology or it needs to be constrained to specific conditions and is not true in general. Anyone?
292
I don't know if this helps, but the general formula for the frequency ratio between emitter and receiver is (A,B label two observers)
[tex]\frac{\nu_A}{\nu_B}=\frac{(g_{ab}k^au^b)_A}{(g_{ab}k^au^b)_B}
[/tex]
where [itex]k^\mu[/itex] is the null geodesic connecting A and B and [itex]u^\mu[/itex] the four-velocity of the observer. The conditions for [itex]k^\mu[/itex] to be a null geodesic are that [itex]\nabla_\nu k_\mu k^\nu = 0[/itex] and [itex]g^{\mu\nu} k_\mu k_\nu = 0[/itex] .
It is clear that the contributions from the velocity and the metric cannot be separated in a unique way. But if A and B have the same velocity then only contributions from the metric will be present.
That formula gives the special relativistic Doppler effect if [itex]k^\mu=(1,1,0,0)[/itex], [itex]u^\mu_{(A)}=(1,0,0,0)[/itex] and [itex]u^\mu_{(B)}=(\gamma,\gamma\beta,0,0)[/itex] ( with [itex]g^{\mu\nu}=\eta^{\mu\nu}[/itex]).
Sure, but this only rules out a purely Doppler cosmological redshift in a static spacetime. Most people will not agree that cosmological redshift is exactly the same as the Doppler effect.
Contributions from the metric seem to take some part in cosmological redshift too.
How do you make this distinction between local and global coordinates? GR is a local geometry theory and the metrics that are solutions to the GR equations are always expressed in "local" coordinates (3,1) because they are describing the intrinsic spacetime curvature. Global cordinates would have to belong to a embedding in higher dimension coordinates, at least that is what they do with de Sitter and anti de Sitter spaces, they are often described in terms of a 5 coordinate embedding to cover the whole spacetimes.
292
My understanding is that the metric is expressed in global coordinates that cover some or all of the manifold. Local coordinates are related to worldlines, with a local Minkowski frame at every point on a timelike worldline. The transformation between global and local frame coordinates is done with a change of basis using the frame field ( a tetrad ).
There seems to be some terminology confusion here. If the coordinates cover a patch of the manifold they are not global, in this sense global coordinates refer to those that cover the whole manifold, wich in the case of a curved manifold unlike in flat manifolds would need to have more coordinates than the original manifold patch coordinates.
These local coordinates refer to local inertial coordinates, or Minlowski local frames at infinitesimal points of a GR manifold by the Equivalence principle. When I said local coordinates I meant what you call global coordinates, or the usual coordinates of the line element that cover a patch of the manifold. And by global coordinates I meant those that determine the topology and cover the whole manifold.
(To avoid confusion: space in the following is short for spacetime.)
Global coordinates for me are coordinates that cover the whole manifold, p.ex. cartesian coordinates for Minkowski space. Every point of Minkowski space is described by one coordinate tuple (x,y,z,t), and to every coordinate tupel there belongs a point of Minkowski space. Coordinates which are not global for Minkowski space are for example Rindler coordinates: every tuple of Rindler coordinates corresponds to a point in Minkowski space, but there are points in Minkowski space which do not have a corresponding tuple. "Local" coordinates don't have meaning in that concept; coordinates are either global or not. This does not imply that we cannot describe space locally, in the neighbourhood of one point, with a coordinate system and in the neighbourhood of another point with another.
An example of global coordinates for de Sitter space is given by ds² = - dt² + H^{-2} cosh²(H t) dΩ², where dΩ² is the metric of the 3-sphere. We don't need an embedding in a higher-dimensional space for global coordinates; but there are spaces which don't admit global coordinates (I think the Kerr black hole falls in this class).
Related Threads on Coordinate matters
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
