Coordinate matters
(To avoid confusion: space in the following is short for spacetime.)
Global coordinates for me are coordinates that cover the whole manifold, p.ex. cartesian coordinates for Minkowski space. Every point of Minkowski space is described by one coordinate tuple (x,y,z,t), and to every coordinate tupel there belongs a point of Minkowski space. Coordinates which are not global for Minkowski space are for example Rindler coordinates: every tuple of Rindler coordinates corresponds to a point in Minkowski space, but there are points in Minkowski space which do not have a corresponding tuple.
I think it is useful to make the distinction I made earlier between flat and curved manifolds. The example of Minkowski space is relevant, being a flat manifold you can cover the whole manifold with a 4 coordinate metric, the same happens with Euclidean space that can be covered with three coordinates or the plane with two. However in the case of a two sphere for instance the line elements expressed in 2 coordinates cover patches of the total manifold and there are always points like at the equator or at the poles dpending on the specific coordinates where one finds coordinate singularities, where you have to transform coordinates to a different overlapping patch of the manifold.
So in curved manifolds, (unless some hidden symmetry is exploited) I would say global coordinates need one more coordinate to cover the whole manifold.
An example of global coordinates for de Sitter space is given by ds² = - dt² + H^{-2} cosh²(H t) dΩ², where dΩ² is the metric of the 3-sphere. We don't need an embedding in a higher-dimensional space for global coordinates; but there are spaces which don't admit global coordinates (I think the Kerr black hole falls in this class).
Yes, those are de sitter global coordinates, and are a Minkowkian 5-dimensional ambient space restricted to dS^4 (see http://www.bourbaphy.fr/moschella.pdf equations 3-8)
Note de sitter geometry is very special, being maximally symmetric.
True; technically this is a coordinate singularity is you use polar coordinates for the sphere. However, you can for example obtain its area by integrating dA = sin θ dθ dφ over the whole sphere, and so it's an integrable singularity. Those typically don't cause any problems, so let's include them in the definition of global coordinates: coordinates which at most have integrable singularities.
You can define de Sitter space by the embedding into a 5-dimensional manifold and can of course get global coordinates by restricting 5-dimensional global coordinates to the de Sitter manifold in a reasonable way, but the point is that you don't need to do it. You can as well define de Sitter space by saying that topologically it is R x S³ and by giving its symmetry group. Using coordinates adapted to the topology you then get the coordinates I gave you, unambigously and without the need to embed de Sitter in any higher-dimensional space.
We basically agree, as always there is a nagging problem of terminology.
I was using the word "gobal" in a more topological than geometrical way. And in this sense the coordinate systems on n=manifold dimensionality can never be global, you need the embedding. But I admit this is kind of trivial and in the definition of manifold.
The conclusion is that within the dimensionality n of the manifold at hand, in the case of the manifold being intrinsically curved, one can never cover all the points of the manifold with coordinates of the same dimensionality n of the manifold, this follows from the fact that the line element is a infinitesimal Euclidean (or Minkowskian, but flat in any case) local representation of the manifold, and one can't make something curved fit a flat space without tearing it as cartographers know well. However, within the choice of coordinates for a given manifold the choice goes from coordinates that cover a small part of the manifols to coordinates that cover almost all the points of the manifold depending on the manifold and the ability to find coordinates.
You are right. But note that even if you don't need to embed it, actually the coordinates in the line element of the manifold you gave was defined from the Minkowskian 5-dimensional ambient pace, the parameter H^-2 or 1/R^2 belongs to 5-dimension space.
Like in the 2-sphere case you find the trivial singularities for the r=0, r=pi, Theta=0, Theta=pi... if you express the 3-sphere spatial part in spherical coordinates or the corresponding ones if you express it in other coordinates.
BTW,you mentioned in a previous post that in the case of the Schwazschild manifold:"In the right coordinates, the Schwarzschild spacetime has no interior, so there is no black hole. But that's just because those coordinates aren't global." I find this statement slightly contradicting your inclusion of coordinates with trivial singularities (like r=2m in this case) in the definition of "global coordinates"
The parameter H is intrinsically defined in de Sitter space: it's R/12 in the four-dimensional case, where R is the curvature scalar. I don't need any embedding for it, period.
If you want to embed de Sitter space, then H is the radius as seen from the embedding space, but H is not a five-dimensional parameter, as you put it. That's just not true.
To counter your statement that no curved manifolds exist without coordinate singularities: take the manifold R x S¹, with coordinate system ds² = dx² + cosh² x dφ², with -∞ < x < ∞ and 0 ≤ φ < 2π. This is regular everywhere, it has not even integrable singularities.
The case θ=0 is very different from the case r=2M. Calculate, for example, the geodesic equation for a particle travelling outwards, from r = r_0 to infinity, at any θ=const, including θ=0. You don't have any problem as long as r_0 > 2M, it doesn't matter if θ=0 or θ=π/2, or any other value. For r_0 = 2M, however, you have a problem.
That's why the coordinate singularity at θ=0 is ignorable, but the one at r=2M is not.
(calculation of Christoffel symbols usually is a mess, so here they are, for your convenience: http://theory.gsi.de/~vanhees/faq/gravitation/node65.html)
I'm not sure if we are talking at cross purposes or you are not getting what I'm saying. I didn't "put it" like that at all. I didn't deny the 4-dimensionality of the topology of the manifold, I was just alluding to the way that line element is usually defined in order to be easily visualized. Just see the WP page for de Sitter space or "The large scale structure of space-time" by Hawking and Ellis pg. 124.
Well, I specified "intrinsically" curved manifolds, if you give me the example of the topology of a cylinder wich only has extrinsic curvature, you are not really countering any statement.
I'm not saying those two cases are the same , it is stated in most GR books that the r=2m singularity is similar to the θ=0 singularity in that they are both coordinate singularities. If you disagree with it that is fine with me.
  • #31
169
I don't want to offend you in any way, if you felt I have done this. But it seems to me that you don't understand some (subtle) points, and I want to explain them to you.
I may have misinterpreted your statement
you gave in your post before the last, but to me you were stating that H is a five-dimensional parameter which doesn't really belong into four-dimensional de Sitter space. And that's false. It has a five-dimensional interpretation, but that's all.
What I gave you is two-dimensional de Sitter space, not a cylinder. Topologically both are R x S¹, but de Sitter space has intrinsic curvature, namely in the case I gave you R = 2. Take the metric and calculate to see it yourself, please.
... it is stated in most GR books that the r=2m singularity is similar to the θ=0 singularity in that they are both coordinate singularities. If you disagree with it that is fine with me.
I have explicitely said that θ=0 is a coordinate singularity, but an ignorable one, and I gave you my reasons. I did it in detail because you were stating before
, but that's not what I said neither meant, and I wanted to clarify it. r=2M is not a trivial singularity, but θ=0 is, and I explained you why I think this is so. And all GR specialists I have met until today agree on this, although of course I haven't met all ;)
  • #32
3,507
Oh, by all means, enlighten me, I'm pleased that you are willing to explain what I don't understand
So it has the topology of a cylinder, but it has intrinsic curvature, this is a bit over my head, I thought you needed more than one chart to cover a whole intrinsically curved manifold, maybe this belongs to the topology subforum rather than the relativity one anyway.
This is interesting, I was interpreting "trivial" in the sense of physically trivial, and everybody seems to agree there is nothing physically special at the BH event horizon, do you opine otherwise? It seems like the whole BH notion rests upon that singularity being trivial in this sense.
From Ryder GR book:"We may note here, however, that the ‘singularity’ r=2m is more like a coordinate singularity than an actual singularity in the geometry. By analogy, at the
north and south poles on a sphere ... The (contravariant components of the) metric tensor may become singular, but nothing unusual appears at the poles; a sphere is, after all, a homogeneous space, and no one point is different from any other point."
  • #33
3,507
I'm not saying that is not regular, I'm just saying that it can't be completely covered with one chart of polar coordinates.
  • #34
169
So now you know that there are intrinsically curved manifolds where you only need one chart. The topology doesn't fully specify the metric; there are infinitely many possibilities to bestow a given topological manifold with a metric.
We didn't understand each other saying "trivial" :)
There are two types of singularities: coordinate singularities and physical singularities.
A physical singularity is a point (or curve, or any submanifold) where a curvature invariant (a scalar, like R or R_{abcd} R^{abcd}, or R_{ac} R_{bd} R^{abcd}, or whatever you can think of - as long as it is a scalar) diverges. Since scalars don't change under a change of coordinates, you cannot get rid of such singularities. An example for a physical singularity is r=0 in the Schwarzschild metric.
A coordinate singularity is a submanifold where a component of a tensorial quantity diverges, like g_{tt} at r=2M in the Schwarzschild metric, although scalar curvature invariants are perfectly finite. Since the components of tensorial objects change under a change of coordinates, we simply have chosen bad coordinates, and in another coordinate system g_{tt} at this point of the manifold is perfectly fine. Now for coordinate singularities there are two subtypes: ignorable ones and ones which significate something. An ignorable coordinate singularity is, as I said, θ=0; r=2M is of the special type. Ryder may be a bit overstating, but since in the first half of the last century many physicists, including Einstein at the beginning, confused physical singularities with coordinate singularities, I think for him it is important to insist on the fact that r=2M is not a physical singularity. And it's not only "more like a coordinate singularity", it is a coordinate singularity :)
For example, take the following Gedankenexperiment: You hover with a spacecraft far away from a black hole. You then lower your outward acceleration, sink towards the black hole and up the acceleration a bit more to hover a bit nearer to the black hole. The point where you need infinite acceleration, you have reached r=2M. However, if you hover at an r>2M and spin around the black hole, nothing, absolutely nothing will change if you reach θ=0.
So r=2M is not a physical singularity since you won't be crushed when you reach this point (this will happen at the physical singularity r=0), but it by no means is a trivial singularity like θ=0.
"Trivial" is a word you need to use with caution; you have physical singularities (r=0) and coordinate singularities, and from the coordinate singularities you have ignorable ones (θ=0) and non-ignorable ones (r=2M).
  • #35
169
Which point is not covered by the coordinate system I gave you?
  • #36
3,507
I might have misinterpreted this from some notes on diff.geometry:
"Note finally that any manifold M admits a finite atlas consisting of dimM +1 (not
connected) charts. This is a consequence of topological dimension theory [Nagata,
1965], a proof for manifolds may be found in [Greub-Halperin-Vanstone, Vol. I]."
I took this to meanthat any manifold with n-dimensions needs at least n+1 charts to cover all its points.
Ok, just one thing, are the terms "trivial" and "ignorable" referred to singularities as you use them standard mathematical notions? I had never heard about ignorable and non-ignorable singularities, but then I'm just a layperson.
  • #37
George Jones
Staff Emeritus
1,150
I took this to meanthat any manifold with n-dimensions needs at least n+1 charts to cover all its points..
I am not familiar with this result, but here is my guess. dimM + 1 refers to the "dimensionality" of the charts, not to the actual number of charts. Suppose M has dimension n. Standard charts on M are maps from subsets of M into R^n. A dimM + 1 chart is something like a homeomorphism between an open subset U of M and its image in R^(n+1).
  • #38
169
With mathematical theorems you must be careful in intepretation, they assure only and exactly only what they state. For each manifold of dimension n (so in my toy example n=2) there is an atlas containing n+1 charts, so you don't need more. Of course you can take more if you wish, and there are examples where you can take less. Minkowski space (of dimension n) is such an example, it is a manifold of dimension n where you only need one chart to cover it completely (but of course you can find n+1 charts, or more). It is an interesting theorem, though; I can see why for some manifolds you need at least n+1 charts, but not why this is sufficient. Let's look up this Greub-Halperin-Vanstone!
"Ignorable" is not a standard mathematical term, it's physics parlor. Trivial is a standard mathematical term, but as in "that's trivial to show", not for coordinate singularities. Non-ignorable coordinate singularities define a horizon (which may be one of: event horizon, black hole horizon, null horizon, Killing horizon, ...), and that's a standard mathematical term you can look up.
  • #39
3,507
Thanks for the info. You are right that the theorem doesn't mean what I thought.
I know now that there are curved manifolds that can be specified with jst one chart, you may wanna look up the thread on manifold charts I started in the Topology subforum.
Hmm... How about point phi=pi?, I believe the maps have to be bijective, and a single chart can't have both phi=0 and phi=pi.
  • #40
169
True, but that's not a point on the manifold (sure you meant φ=2π, no?). My φ coordinate is in the range [0, 2π), so it includes 0 but excludes 2π. So everything ok there.
(if you want strictest mathematical rigor: φ ∊ ℝ/{2πℤ})
  • #41
George Jones
Staff Emeritus
1,150
What I wrote was silly, but I guessed (wrongly) that the number was too small, e.g., that there probably exist 3-dimensional manifolds not coverable by four charts.
[EDIT]
[/EDIT]
Not available to me.
  • #42
3,507
No, I actually meant two opposite points in the S^1 part of the your manifold (if you picture it as a one-sheet hyperboloid, think of a point at the front and the diametrically opposite point in the back side of the hyperboloid)
I know for sure that S^1 needs two charts to specify all its points (proof in Tensor calculus by D. Kay, page 244) due to the bijective (one-one) character of the manifold maps and so I figured that if the slices of constant x have circular shape in the hyperboloid, it seems logical that this manifold also needs more than one chart. Only one chart would for some applications map the 2 opposite points in the circumference of a slice of constant x to the same real number.
Related Threads on Coordinate matters
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
