Coordinate System
Philosophaie
462
MENTOR note: moved from General Math hence no template
What would be the Y-Axis if:
X-Axis: theta=266.4 phi=-28.94
Z-Axis: theta=192.85 phi=27.13
where:
theta=atan(Y/X)
phi=asin(Z/R)
My thinking, theta is +90 from X-Axis and phi is -90 from the Z-Axis.
Is the Y-Axis theta=356.4 phi=-62.87?
Answers and Replies
Ray Vickson
Dearly Missed
10,706
1,722
where:
theta=atan(Y/X)
phi=asin(Z/R)
Are these supposed to be angles in a spherical coordinate system? If so, please specify precisely which convention you are using. There are two common, but different conventions: (1) ##\theta = ## angle between the ##z##-axis and the vector ##(x,y,z)##, ##\phi = ## angle from the positive ##x##-axis, with counterclockwise angles being positive (so ##\phi## = longitude, measured west to east and ##\theta## = latitude, measured down from the North pole); and (2) the roles of ##\theta## and ##\phi## are swapped from the previous use. Convention (1) is most common in Physics, while (2) is used a lot (but not universally) in Math.
Philosophaie
462
I thought:
theta=atan(Y/X)
phi=asin(Z/R)
explained it.
In spherical coordinates:
theta is measured on the x-y plane from the x-axis.
phi is measured upward from the x-y plane to the z-axis.
Ray Vickson
Dearly Missed
10,706
1,722
I thought:
theta=atan(Y/X)
phi=asin(Z/R)
explained it.
The usual convention for a ##\phi## like yours would be ##\phi = \arccos(z/r)##, so ##\phi## would be latitude as measured down from the north pole; see, eg., the second figure in https://en.wikipedia.org/wiki/Spherical_coordinate_system or the diagram in http://mathworld.wolfram.com/SphericalCoordinates.html or http://tutorial.math.lamar.edu/Classes/CalcIII/SphericalCoords.aspx .
In any case, if you can determine (in ##(x,y,z)##-space) the vectors ##\vec{e_X}## and ##\vec{e_Z}##, which are the unit vectors along the ##X## and ##Z## axes, you can take ##\vec{e_Y} = \vec{e_Z} \times \vec{e_X}## as the unit vector along the ##Y## axis. (Here, ##\times## denotes the vector cross-product.)
Likes Philosophaie
Suggested for: Coordinate System
  • Last Post
  • Last Post
  • Last Post
  • Last Post
