Proving a Quadrilateral is a Parallelogram
  • Thread starter lovemake1
  • Tags
    Planes
Reduced to : p4y - p2y / p4x - p2xm2 to m3 : p3y + p4y -...+ (p2y + p3y) / p3x + p4x -...+ (p2x + p3x) Reduced to : p4y - p2y / p4x - p2xm1 to m4 : p1y + p4y -...+ (p1y + p2y) / p1x + p4
lovemake1
149
p1(x1,y1) , p2(x2,y2), p3(x3,y3), p4(x4,y4) are the vertices of a quadrilateral. Show that the quadrilateral formed by joining the midpoints of adjacent sides is a parallelogram.
Midpoint = x1 + x2 / 2 and y1 + y2 / 2
im not quite sure of what the question is asking...
"show that quadrilateral formed by joining the midpoints of adjacent sides is a parallelogram"
isnt this just mean cut the original paralleogram in half ? and still proove its a prallelogram ?
how can a trapezoid for example turn into parallelogram after joining the midpoints of adjacent sides... right it cant..
This is why the question is so misleading to me..
can anyone give me a small clue? so i can try to figure this question out by myself thanks !
No, you're given a quadrilateral - it's not give that it's a parallelogram. The question is saying that if you connect the midpoints of any four-sided figure, what you get is a parallelogram
No, not right. The resulting figure is a parallelogram, and that's what you need to prove, except you can't assume you're starting with a trapezoid (or rectangle etc).
Find the midpoints of all four sides.
Calculate the slopes of the opposite sides of the figure you get. If the slopes are equal, you have a parallelogram.
hmm. so you mean like a form a diamond within the 4 sides right ? i was more of thinking adjacent sides meaning one side that's not touching the other.
so like one across from another, making an X shape.
so if we were to form a diamond, how would we use 4 points to find the slope?
i know that y1 - y0 / x1 - x0 is slope for one side. But that doesn't give me any clue to if the sides have same slope.
i've got all 4 Mid points of each sides.
just using the variables P1x, P2x, P3x, P4x, Py1, Py2, Py3, Py4.
Each Midpoint looks like this. Midpoint-1: (P1x + P2x) / 2 , (P1y + P2y) / 2
after getting 4 mid points, I've tried to get slope from using these points.
They looked as follows: Slope of midpoint 1 and 4 = [(p1x + p4x) - (p2x + p3x) / 2] / [(p1y + p4y - p2y + p3y)/2]
am i on the right track here?
i can compare this with slope of midpoint 2 and 3 which is opposite of midpoint 1 and 4.
For some reason i did not get the same variable.
am i doing this completely wrong ? please help
Yes, only it's not a diamond. You're proving that it's a parallelogram.
Adjacent sides do touch (meet). Opposites sides don't meet.
Compare (y1 - y0) /(x1 - x0) for one segment with the slope of the segement across from it. If you're not drawing a picture of this, you should be.
Maybe. It's hard to say for sure without seeing a picture. If your four midpoints are M1, M2, M3, and M4 (going around the figure, clockwise or counterclockwise), you want to compare the slope of the segment from M1 to M2, with the slope of the segment from M3 to M4, and do the same for the segment from M2 to M3 compared to M4 to M1.
NVM. i had the right answer in the first place.
i was very stupid. didnt sub in the right variables :D
Thanks, problem solved !
I haven't worked it out, but I think it should work. Assuming that M1, M2, M3, and M4 are the midpoints of the original quadrilateral, and are labelled going around, what do you have for the slope from M1 to M2 and for M3 to M4?
m1 to m2 : p2y + p3y - (p1y + p2y) / p2x + p3x - (p1x + p2x )
Reduced to : p3y - p1y / p3x - p1y
m4 to m3 : p3y + p4y - ( p1y + p4y ) / p3x + p4x - ( p1x + p4x )
Reduced to : p3y - p1y / p3x - p1x
P.S- I removed the division of 2 from the midpoint equation. because they cancle out.
Got this answer. This is the correct method to achieve the solution right ?
The Slope of the two lines seems to match.
If the slopes of two opposite sides are equal, that's what you wanted to show. Now show that the slopes of the other two opposite sides are equal, and you'll be done.
1. How do you prove a quadrilateral is a parallelogram using its sides and angles?
To prove a quadrilateral is a parallelogram, you can use the following methods:
  • Prove that opposite sides are congruent.
  • Prove that opposite angles are congruent.
  • Prove that one pair of opposite sides is both parallel and congruent.
2. Can a quadrilateral be a parallelogram if it has only one pair of parallel sides?
Yes, a quadrilateral can still be a parallelogram if it has only one pair of parallel sides. This is because a parallelogram only needs one pair of parallel sides, and the other pair will automatically be parallel as well.
3. What is the difference between a rhombus and a parallelogram?
A rhombus is a type of parallelogram with four equal sides, whereas a parallelogram can have two pairs of equal sides or no equal sides at all. Additionally, a rhombus also has all four angles equal, while a parallelogram does not necessarily have equal angles.
4. Can you prove a quadrilateral is a parallelogram if you know its diagonals are congruent?
Yes, you can prove a quadrilateral is a parallelogram if you know its diagonals are congruent. This is because in a parallelogram, the diagonals bisect each other, meaning they divide each other into two equal parts. Therefore, if the diagonals are congruent, the two pairs of opposite sides are equal, making it a parallelogram.
5. What is the difference between a rectangle and a parallelogram?
A rectangle is a type of parallelogram with four right angles, whereas a parallelogram can have any angle measure. Additionally, a rectangle has two pairs of equal sides, while a parallelogram does not necessarily have equal sides.
9K
16K
  • Linear and Abstract Algebra
