Calculating New Northward Speed of Air Parcel
  • Thread starter Mearskii
  • Tags
    Air Speed
In summary, the problem asks for the new northward speed of a parcel of air that initially moves northward at a speed of 10 m/s at 45°S. The Coriolis force, which is affected by the latitude and angular velocity of the Earth, changes the direction of the parcel's velocity but not its speed. Therefore, the northward component of the velocity is what is being asked for in the problem.
Mearskii
A parcel of air initially moves northward at a speed of 10 m/s at 45°S. After two hours, determine the new northward speed.
Energy of a parcel= u^2+v^2
The Coriolis force accelerates a parcel such that, du/dt=fv and dv/dt=-fu
where f=2Ωsin[itex]\varphi[/itex] [itex]\varphi[/itex] =latitude and Ω=angular velocity of earth
My first question about this problem is in regards to what it is asking for. It says to find the new northward speed of the parcel, however the Coriolis force only changes direction, not speed. So I then considered that the northward component of speed would change and that must be what the question is asking for. But then I thought about how speed is a scalar, not a vector, so there would be no "northward component" of speed because there simply aren't speed vectors. Please correct me if I'm wrong.
Welcome to PF,
So you're just hung up on terminology? The "northward speed" means the speed in the northward direction, which is the magnitude of the northward component of the velocity.
1. How do you calculate the new northward speed of an air parcel?
To calculate the new northward speed of an air parcel, you need to know the initial northward speed and the forces acting on the parcel. You can use the equation: New northward speed = Initial northward speed + (Net force / Mass) x Time.
2. What is the net force acting on an air parcel?
The net force acting on an air parcel is the sum of all the forces acting on the parcel. These forces include wind, gravity, and pressure gradient force.
3. How does wind affect the northward speed of an air parcel?
Wind can either increase or decrease the northward speed of an air parcel, depending on the direction and strength of the wind. If the wind is blowing in the same direction as the parcel's initial northward speed, it will increase the speed. However, if the wind is blowing in the opposite direction, it will decrease the parcel's northward speed.
4. How does gravity affect the northward speed of an air parcel?
Gravity acts in a downward direction and can affect the northward speed of an air parcel by causing it to accelerate or decelerate. This is because gravity is a force that pulls objects towards the center of the Earth. If an air parcel is moving upward, gravity will slow it down. On the other hand, if an air parcel is moving downward, gravity will speed it up.
5. What is the purpose of calculating the new northward speed of an air parcel?
Calculating the new northward speed of an air parcel is important in understanding the movement and behavior of air parcels in the atmosphere. It can help scientists predict the path and speed of weather systems, such as storms or hurricanes. It is also essential in studying atmospheric dynamics and the global circulation of air.
  • Classical Physics
