Corrosion and Rust: What is Corrosion & Why Do New Layers Form?
In summary: This is why iron continues to rust and corrode even if it has a layer of iron oxide on the surface. In summary, corrosion is the process of decaying and wearing away of metals through chemical reactions, specifically redox reactions. When a metal corrodes, a layer of oxide forms on the surface, which protects the metal from further corrosion. However, not all metal oxides are equally effective in preventing corrosion, as some may be porous and allow oxygen to continue corroding the underlying metal. This is why corrosion is an important topic in material science, as the study of it helps in understanding how to prevent and control it.
gracy
2,486
83
what corrosion really is?my teacher says it is disintegration and decaying of metals via chemical and more precisely redox reaction.so according to my teacher corrosion is the wearing away of a metal through a chemical reaction.my question is as corrosion is process of decaying,wearing away then why there is formation of new layers rather than disintegration of already existing layer? for eg.when Aluminum corrodes, forms a thin layer of aluminum oxide over the surface of the metal and also when Copper corrodes produces the green color layer known as patina
Chemistry news on Phys.org
Layer of oxides is typically weaker than the metal itself, and quite often only lousily attached. As it is the metal below that is strong and capable of carrying the load, when part of the metal is removed, whatever is left is weaker than it initially was.
Likes Dino
sorry but i didn't understand.i am asking as corrosion is process of decaying,wearing away then why there is formation of new layers rather than disintegration of already existing layer? for eg.when Aluminum corrodes, forms a thin layer of aluminum oxide over the surface of the metal and also when Copper corrodes produces the green color layer known as patina.
Not all metal oxides, which is what happens when metal corrodes, form in the same way.
For example, when aluminum corrodes, a thin layer of oxide forms between the aluminum metal and the ambient environment, and this layer prevents further corrosion of the aluminum from taking place, unless the oxide coating is disturbed or removed.
http://en.wikipedia.org/wiki/Aluminium_oxide
The aluminum oxide does not have a color which is that different from pure aluminum, thus weathered aluminum is a lot like pure aluminum in appearance.
Iron and many iron alloys form oxides which don't have the same physical characteristics as aluminum oxides. Most notably, the oxides of iron can range in color from orange to black. Second, the oxides of iron are much weaker than iron itself, so any protection the iron oxide layer provides to the base metal will be lost when the iron oxide coating weathers away. Once this happens, corrosion continues in cycles until all of the iron is converted to oxide form.
http://en.wikipedia.org/wiki/Corrosion
The study of corrosion and how to control it and prevent it forms an important part of material science.
Likes Dino
The new layer doesn't grow on the metal object. It replaces the outermost part of the object. Once patina, rust or aluminium oxide forms, there's less of the original pure metal left. If somethig then removes the new layer (very easy with rust), the deeper layers can oxidize in turn, leaving even less of the original object intact.
hmm...now it makes sense to me.patina and aluminium oxide etc prevents further oxidation i.e corrosion of metals right ?but i think rust doesn't prevent further oxidation of metals or (original object)am i correct?
In most cases oxides produced don't protect the metal surface. Sometimes they do - which is why aluminum and copper are quite popular in some applications.
Note, that patina on the copper is not just an oxide, it is rather a basic copper carbonate.
Aluminum and copper oxides are more dense, and once the oxide layer covers the entire surface, fresh oxygen cannot penetrate the oxide layer and form an oxide with the underlying metal. Iron oxide is very porous and oxygen molecules can pass through the iron oxide and reach the underlying iron and form new iron oxide.
Likes gracy
1. What is corrosion?
Corrosion is a natural process that occurs when metal is exposed to certain environmental conditions, such as moisture, oxygen, and chemicals. It involves the gradual destruction of metal through chemical reactions, resulting in the formation of oxides or salts on the surface of the metal.
2. Why does corrosion occur?
Corrosion occurs because metals tend to revert to their natural state, which is an oxide or sulfide form. This process is accelerated by exposure to certain environmental factors, such as moisture, oxygen, and acids, which can speed up the chemical reactions that cause corrosion.
3. What are the effects of corrosion?
Corrosion can have various effects on metals, including weakening the structural integrity, reducing mechanical strength, and causing discoloration or staining. In some cases, corrosion can lead to the failure of metal structures, which can be dangerous and costly.
4. How can corrosion be prevented?
Corrosion can be prevented through various methods, including the use of protective coatings, such as paint or zinc plating, to create a barrier between the metal and the environment. Other methods include cathodic protection, which uses a sacrificial anode to protect the metal, and controlling the environmental conditions, such as reducing moisture and acidity levels.
5. What is the difference between corrosion and rust?
Rust is a specific type of corrosion that occurs on iron or steel surfaces. It is caused by the reaction of iron with oxygen and moisture, resulting in the formation of iron oxide. While corrosion can occur on various metals, rust only occurs on iron and steel. However, rust is often used to refer to any type of corrosion, especially when it results in the reddish-brown discoloration commonly associated with iron oxide.
  • Materials and Chemical Engineering
  • General Discussion
Writing: Read Only Great Lakes Earth
