Cos(x)+sin(x) = 0, Find all values?
  • Thread starter Thread starter DrummingAtom
The equation cos(x) + sin(x) = 0 has a primary solution at x = 3π/4. Additional solutions can be found by adding integer multiples of π to this value, resulting in an infinite set of solutions. The confusion arises from a calculator error when evaluating cos(7π/4) + sin(7π/4), which yields a value close to zero but not exactly zero. This discrepancy is attributed to the limitations of the calculator's precision. The initial approach to finding the solutions is correct, and the calculator's output does not invalidate the solution.
DrummingAtom
I've found the first solution, which is 3pi/4 and I figured I can just add pi to that value over and over to obtain the infinite other values. But when I punch it in my calculator it's coming up that cos(7pi/4)+sin(7pi/4) = 0.000000000021
I'm not sure if this is a calculator computation issue or I'm doing something wrong.. Thanks for any help.
No, you're not doing anything wrong. This error is due to the calculator.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
