Cosine Fourier transform
  1. Dec 25, 2012 #1
    Find the cosine Fourier transform of the function f(t)=e-at
    2. Relevant equations
    3. The attempt at a solution
    F(w)=(2/π)0.5∫dt e-atcos(wt)
    The integral is from 0 to +∞
    Using euler's formula I got the result
    F(w)=(2/π)0.5( eit(w-a)/i(w-a) - e-it(w+a)/i(w+a) )
    I don't know what to do from here... I can't just substitute!
    If anyone could point me in the right direction I'd appreciate!
  3. Dec 25, 2012 #2
    Simon Bridge
    You need a common denominator don't you?
    If I understand you correctly - you converted the cosine in the integral into a sum of exponentials, then did the integration?
    That would give you something like:
    $$e^{-at}\cos(wt)=\frac{1}{2} e^{-at}\left ( e^{iwt}+e^{-iwt} \right ) = \frac{1}{2}\left (e^{(iw-a)t}+e^{-(iw+a)t}\right )$$ ...in the integrand - which does not look like it ends up looking like yours. Can you show the intermediate steps in your working?
    Alternatively:
    You could try using integration by parts instead (hint: twice).
  4. Dec 26, 2012 #3
    You're correct. I made a mistake! The actual result is:
    [itex]{\frac{1}{2\sqrt{2π}}\left[\frac{exp(t(iw-a))}{iw-a}-\frac{exp(-t(iw+a))}{iw+a}\right]}[/itex]
    The problem remains tho... I don't know what to do from here, since I'm integrating from 0 to ∞ !
  5. Dec 27, 2012 #4
    Simon Bridge
    Applying the limits - ##t=0## case is easy. It is ##t\rightarrow \infty## in the first term that gives you the problem?
    To procede from here you need to convert the exponentials back into cosine and sine functions ... think in terms of a product of and exponential and trig functions.
    I still think it is easier to just follow the hint in post #2.
  6. Dec 27, 2012 #5
    I tought about using your hint, but I'd end up with cosine and sine functions, and neither of them converge to a value as x goes to infinity! That's why I avoided using it!
  7. Dec 27, 2012 #6
    Dick
    I think there is probably an unstated assumption that a>0. So your trig functions don't converge but they are bounded. e^(-at) goes to zero as t->infinity. What happens?
  8. Dec 28, 2012 #7
    Simon Bridge
    Thanks Dick - yes: that would be a problem if the trig functions were not multiplied by a decreasing exponential.
Similar Discussions: Cosine Fourier transform
  1. Fourier Cosine Series (Replies: 6)
Loading...
