Cosine rule
  • Thread starter Natasha1
ABC is a triangle
The angle A = 30 degrees
AB = 7cm
BC = 5 cm
C is an acute angle. Find the size of angle C?
I need to use the cosine rule here Cos C = (a^2 + b^2 - c^2) / 2ac
The problem is I do not know the size of side b?
So how can I attempt to resolve the answer?
Cos C = (5^2 + b^2 - 7^2) / 2*5*7
Answers and Replies
Ray Vickson
Dearly Missed
10,706
1,722
ABC is a triangle
AB = 7cm
BC = 5 cm
Why do you need to use the cosine rule? Did somebody tell you that you are being forced to use it?
Just use whatever tool is the most convenient. If I were doing it I would let the points be at ##A = (0,0), B = (7,0), C = (x,y).## You can use the information about angle A and distance BC to get two equations in ##x, y##. These can be reduced to a single equation in ##x##, which is solvable without too much trouble.
Thanks Ray but we have never used this method in class and I am sure this is the approach my teacher wants us to do it. Can I not use the cosine rule or sine rule then?
gneill
Mentor
20,937
2,878
One way or another you'll have to find side b if you're going to apply the cosine rule. If you're not comfortable jumping right into the algebra with a method you've not used before, then start with a diagram and come up with a plan from there.
Likes neilparker62
BvU
14,612
3,822
BvU
14,612
3,822
What about this second option ? :smile:
Ah ha!
cos A / a = sin C / c
So cos 30 / 5 = sin C / 7
So sin C = 7*(cos 30 / 5) = 1.212435565
How do I get the angle?
BvU
14,612
3,822
Ah ha!
sin A / a = sin C / c
So sin 30 / 5 = sin C / 7
So sin C = 7*(sin 30) / 5 = 0.7
arcsin gives 44.4 degrees
Likes Delta2 and FactChecker
286
In general you will use the cos rule for solving a triangle if the givens are the 3 sides or alternatively 2 sides and an angle formed between the 2 given sides.
7,307
Ah ha!
It could be that there are two different triangles that satisfy the given measurements, as in the drawing in post #4. If ##\sin(C) = .7## there is also another angle that is possible for C.
Edit: Since it is stated in post #1 that C is an acute angle, the above does not apply.
BvU
14,612
3,822
gneill
Mentor
20,937
2,878
It could be that there are two different triangles that satisfy the given measurements, as in the drawing in post #4. If sin(C)=.7sin⁡(C)=.7\sin(C) = .7 there is also another angle that is possible for C.
Actually, that was my primary reason for posting the diagram. Too subtle?
gneill
Mentor
20,937
2,878
Maybe too subtle, since the OP didn't seem to pick up on it.
:frown: Okay, will a tad more blatant in future. I hate blatant when gently nudging :smile:
SammyS
Staff Emeritus
1,045
I thought that it was just subtle enough.
symbolipoint
Education Advisor
1,340
I drew the diagram according to original problem description, and intuition tells me that b, and angle B, and angle C are not locked into any set of single values. Not a unique triangle. That's only first impression.
Thinking further,
forget about trying Law Of Cosines.
Law Of Sines seems fitting:
sin(C)/7=sin(30)/5
sin(C)=(7/5)sin(30)
sin(C)=7/10
and from this you could get value for angle C.
Now, you could use AB, BC, and angle at B, to find b, using Law Of Cosines.; but you could use Law Of Sines again if you want.
BvU
14,612
3,822
I drew the diagram according to original problem description, ....
Why come with this now, when OP has cracked the case in #9 ?
symbolipoint
Education Advisor
1,340
Post was not old. I had to try the problem myself to see if or where Law Of Cosines would be useful; and I edited my own post twice within 20 minutes. Post #9 did not indicate any use of Law Of Cosines.
BvU
14,612
3,822
Related Threads on Cosine rule
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
