Could u with this simple problem ?
  • Thread starter hsnelect
In summary, the user asked for help with a circuit problem and was given guidance on how to use the V=IR equation to find the voltage drops across each resistor and then use the loop method to find the two missing voltage sources. They were also reminded to pay attention to the polarity of the voltage drops and gains. The user successfully found the correct values for the missing voltage sources and was then asked to find the resistance on the top resistor, which was calculated by subtracting the two voltages and dividing by the current. The user expressed gratitude for the help and enjoyed using the forum.
hsnelect
[PLAIN]http://img100.imageshack.us/img100/338/prob1o.jpg
I = V / R
3 + 5 = 8 A
I = V / R
3 + 5 = 8 A
Welcome to the PF.
That looks correct for a)
How would you go about figuring out the rest of the questions?
Thanks Master!
That's really fast respond .. I'm impressed ^_^'
well .. I try to use the formula again I = V / R .. but it's not working .. :(
I heard that we need to use the Loop Method which I have no idea how to use! :(
I wonder how do we fine the equivalent V for the circuit! ??
hsnelect said:
Thanks Master!
You have the resistances and currents for branches 1, 2, and 3. User V=IR to calculate the voltage drops across each resistor. Then the loop method just says that the sum of the voltage drops in any loop has to equal zero. You should be able to use this fact to calculate the two voltage sources.
Great ..
now I calculated the Voltage in each Resistor.
V @ R1 = 9v
V @ R2 = 32v
V @ R 3 = 45v
Now I need to add the sum of the voltage in the first loop and the second loop separately to get the 2 missing voltages ..
so..
9v + 32v + ε1 = 0
and
32v + 45v + ε2 = 0
is that correct ??
hsnelect said:
Great ..
V @ R1 = 9v
V @ R2 = 32v
V @ R 3 = 45v
so..
9v + 32v + ε1 = 0
and
32v + 45v + ε2 = 0
is that correct ??
Yes, very good. Now the only thing to be careful about is the polarity of the voltage drops and voltage gains. Mark a +/- on the ends of the resistors, with the + end where the current enters the resistor (because current flowing through a resistor generates a voltage drop). The voltage sources would normally have their + end being the wide stripe end.
I got it .. ^_^ thanks!
The correct answer for both ε1 and ε2 is:
ε1 = 41v
ε2 = 77v
Great Job! ^_^
now how do we find the R on the top ..?? O_O
ε1 = 41v
ε2 = 77v
Great Job! ^_^
Hint -- just keep using the V=IR equation...
imm .. yeah .. but the problem is .. this R experience two different voltages .. ! .. should I add them together or subtract or what should I do .. how do I know the true voltage on that resistor! :'(
Thanks! ^_^
Thanks! ^_^
If the + terminals were pointing in the same direction for two power supplies in series, you would add the voltages. What should you do in this circuit?
WoW .. you are really physics master! ^_^
we subtract of course! ^_^
R = V/I
=> R = (77-41) / 2
=> R = 18 Ohms
Thanks! ^_^
I really like this Forum! ^_^
1. Can you help me with this simple problem?
As a scientist, I am always happy to assist with problem-solving. Can you provide more details about the problem so I can better understand the issue and provide an effective solution?
2. How can I solve this problem easily?
The best approach to solving a problem is to break it down into smaller, manageable steps. Can you explain the problem to me so we can work together to find a solution?
3. Are there any tips or tricks for solving this problem?
Every problem is unique, but there are some general problem-solving strategies that can be helpful. Have you tried breaking the problem down into smaller parts, or seeking out similar examples for guidance?
4. What if I can't solve this problem on my own?
Sometimes, problems can be challenging and require outside help. Don't hesitate to reach out to others, such as colleagues or experts in the field, for assistance and guidance.
5. Can you recommend any resources for further help with this problem?
There are many resources available for problem-solving, including textbooks, online tutorials, and forums. Can you provide more information about the problem so I can suggest specific resources that may be helpful?
10K
26K
