• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Coulomb's Law problem
1. Homework Statement
Particle 1 of charge q1 = +0.76 µC and particle 2 of charge q2 = -3.0 µC, are held at separation L = 13 cm on an x axis. If particle 3 of unknown charge q3 is to be located such that the net electrostatic force on it from particles 1 and 2 is zero, what must be the x and coordinates of particle 3?
I'm really not sure how to proceed with this question. But I understand that the forces added together is zero.
LowlyPion
3,079
Welcome to PF.
OK. So what equation do you think you might use then?
So I did:
c/d^2 + c/d^2 =0
put in the numbers
(0.76*10^-6)/d^2 = (3*10^-6)/(d+13)^2
simplify taking out the fractions
(0.76*10^-6)(d+13)^2 = d^2(3*10^-6)
expand the bracket
(0.76*10^-6)(d^2+26d+169) = d^2(3*10^-6)
eventual rearrangement
2.24*10^-6 - 1.976*10^-5 - 1.2844*10^-4 = 0
quadratic equation
13 and -4.3 but 13 is not the right answer. It might be my method or calculation error, I'm really not sure.
LowlyPion
3,079
I trust you didn't round away too much from the answer for your quadratic.
If you think about it, ≈ 13 is an expected result, because if 1 charge is 4 times larger and twice as far away ... you'd expect something about equal to the charge separation wouldn't you?
Hum, isn't q2 negative? I reckon you might've used it as a positive..
F1 - F2 = 0 .. so, q1/d^2 = q2/(d+x)^2, where q2 still is negative, and I only see +3 in your calculations :)
LowlyPion
3,079
Actually I think he's taken that into account.
∑F = 0 = q3*∑ E = 0 ⇒ E1 + E2 = 0
Taking account of the sign of the charge then |E1| = |E2| satisfies the condition.
(This of course is for x that does not lie between q1 and q2.)
I don't quite see it, but I reckon you're right 'cause you most definitely know better than I do and it's late & I'm tired. I think I'll come back and try to see it when it's not 20 to midnight ;)
Related Threads for: Coulomb's Law problem
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
