Coulumbs Force question
A charged particle A exerts a force of 2.62microNewtons to the right on a charged particle B when the particles are 13.7 mm apart. Particle B moves straight away from A to make the distance between them 17.7mm. What vector force does it then exert on A?
2. Relevant equations
I know its easy, very, but for the love of god I can't figure this out.
3. The attempt at a solution
I know that they are both positive particles, so im assuming both are +1.60x10^-19c.
Also I believe we use F= (K q1 q2/r^2). Ive tried inserting different things in to the formula but none of it gives me the answer im looking for which is 1.57micronewtons
Delphi51
3,407
Yes, use use F= (K q1 q2/r^2).
No need to assume a charge. Put in the force and distance for the first position, and calculate the value of K q1 q2. This will carry over to the new distance.
Knowing that and the new distance, you can calculate the new force.
Redbelly98
Staff Emeritus
12,028
112
... im assuming both are +1.60x10^-19c.
I wouldn't make that assumption ... I see nothing in the problem statement that would allow this.
Yes, that is the equation for this problem.
Here's a question: what must the product (q1 q2) be equal to, so that the force is 2.62 μN when r=13.7mm?
EDIT: Delphi gave even better advice. What is (K q1 q2) when the force is 2.62 μN and r=13.7mm?
alright, well K=8.99 x 10^9
so the formula should look like this now. r x [square root of F/k] = q1 q2
inputting everything it looks like this
(0.0137m) times square root of (2.62 x 10^-7 N )/(8.99 x 10^9) = 7.39 x 10^-11
equaling that to q1 q2. this is one part im stuck on, I'll be able to get the rest but I don't know what to do with both unknowns.
Delphi51
3,407
If q1 q2 is bothering you, make this change in the formula: C = q1 q2.
Then you will have only the one unknown!
The important thing is that C is a constant in this problem.
Even better: let C = kq1 q2. Saves wear on the calculator!
Redbelly98
Staff Emeritus
12,028
112
Uh, wait, that should be
r^2 x F/k = q1 q2​
there we go, again thanks everyone. that was what was screwing up my answer, I saw another equation like the one I put up for a similar question so I thought I could apply it here. I see now that I can't. again thanks.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
