Counting problems
  • Thread starter duki
how many 4 digit positive integers have at least one digit that is a 2 or a 3?
- this is what I need -
I cannot find the equation to this problem. Can someone give me a hand?
Answers and Replies
jbunniii
Insights Author
255
Can you answer these questions?
(1) How many 4-digit positive integers have NO digits that are 2 or 3?
(2) How many 4-digit positive integers are there?
(3) How can I use (1) and (2) to answer the original question?
I have no clue of #1
without using any formulas, I would just guess the answer is 2222... is that close?
jbunniii
Insights Author
255
Let's start small.
How many 1-digit positive integers have NO digits that are 2 or 3?
How many 2-digit positive integers have NO digits that are 2 or 3?
What's the general rule for an n-digit positive integer?
jbunniii
Insights Author
255
By the way, notice that in order to have a four-digit number, the first digit has one more constraint. It can't be 2 or 3, but it also can't be ...?
49?
7^n?
Hm, so ...
8^(n-1) + 7?
jbunniii
Insights Author
255
49?
7^n?
You're on the right track.
For the FIRST digit you have 7 choices. For all the other digits you have 8 choices. So what's the general rule for n digits?
jbunniii
Insights Author
255
Hm, so ...
8^(n-1) + 7?
Almost but not quite. Hint: it's not a "+", it's a ...?
ahhh... [tex]8^{n-1} * 7[/tex] ?
jbunniii
Insights Author
255
Yes. Do you understand why it's * and not +?
So that answers my question (1).
Now how about question (2)? This is much easier.
Then question (3) is the key.
9998 - 3584 = 6414?
jbunniii
Insights Author
255
9998 - 3584 = 6414?
Close but not quite right.
How many four-digit numbers are there? The first digit has to be 1-9, the other three digits can be anything.
I'm not sure... why is it not 9998?
jbunniii
Insights Author
255
Well, there are 9 choices for the first digit, 10 for the second digit, 10 for the third digit, and 10 for the fourth digit.
So there are [itex]9 \times 10 \times 10 \times 10[/itex] possibilities in total. That's 9000, not 9998.
If that's not clear, consider that you are excluding precisely the numbers 0000 through 0999. That's 1000 numbers excluded, out of 10000 possible combinations of digits, leaving 9000.
Why are we excluding the numbers 0000 through 0999? Because written properly they are 0 through 999, which aren't 4-digit numbers!
So why would 9990 for example not be valid? It is positive and uses 0 in the one's position. I assumed I could not use 0 but I could use 10, 100, 1000, etc.
ooooooooooooooooooooooooooooooooooooooooo, so I have:
9000 -3584 = 5416 that do not have a 2 or 3 ?
jbunniii
Insights Author
255
Bingo!
hurah! mucho gracias! Let's go to my new counting post! :p
Related Threads on Counting problems
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
