Counting Problems
  • Thread starter LostSeeker
----1. From the digits 0, 1, 2, 3, 4, 5, 6, how many four-digit numbers with distinct digits can be constructed? How many of these are even numbers?
----2. How many integers between 1000 and 9999 inclusive have distinct digits? Of these how many are odd numbers?
Use the product rule, etc.
----1. The first question is straight forward.
There are four-digit numbers: _ _ _ _
From left-to-right on possibilities: 6 (can't be zero; hence, 6 versus 7) * 6 * 5 * 4
Answer: 720 possibilities.
The second type of question is where the troubles begin.
Does anyone know of a simple online tutorial that would help? I'm sure this is all obvious but it is not to me.
The following is an attempt. . .
From right-to-left on possibilities: 3 (even numbers), 6 (even or odd), 5 (even or odd), 3 (even or odd but no zero)
Wrong answer: 270 possibilities.
Where am I going wrong?
----2. Again, the first part is easy for the second problem. The answer is 9*9*8*7 = 4,536.
The second part confuses me.
From right-to-left on possibilities: 5 (odd numbers), 9, 8, 6
Wrong answer: 5*9*8*6 = 2,160.
According to the textbook, from right-to-left the answer really is: 5, 8, 8, 7.
Why is this correct? Why those particular numbers?
Answers and Replies
0 is an even number, so you have to choose from 4 digits to start with. Then the rest changes depending on whether or not you chose 0. It will affect the thousands digit.
Are you sure it is right-to-left? I always place my digits depending where stipulations are. So I would place Ones, Thousands, (the order doesn't matter for the others). If your choice affects another position, I try to do that position first, unless there are shared dependencies.
Thank you.
OK, I never thought of zero as an even number. When it comes to evens and odds, I've always considered them natural numbers. The ordering is as you say, as well.
Let me try this once more. . .
But this time I won't work right-to-left.
Ones position: 4 (even numbers)
Thousands position: 5 (non-zero, minus above selection)
Hundreds position: 5 (minus the two above selections)
Tens position: 4 (minus the three above selections)
That's not right, either. 420 is supposedly the answer.
Ones position: 5 (odd numbers)
Thousands position: 8 (non-zero, minus above selection)
Hundreds position: 8 (minus the two above selections)
Tens position: 7 (minus the three above selections)
Answer: 2,240. This appears correct. If that is the case, why not the other problem?
I think you missed what I was saying by a little. It will affect the thousands digit if the ones digit was non-zero; it won't affect the thousands digit if it was zero. You need to do both cases and add them together.
I see. It would be nice if my textbook actually explained the solutions to these problems. Instead it leaves the student in the dark.
Once again, I thank you.
Ones position: 1 (zero as even number)
Thousands position: 6 (anything but zero)
Hundreds position: 5 (minus above two numbers)
Tens position: 4 (minus above three numbers)
Ones position: 3 (non-zero even number)
Thousands position: 5 (non-zero number and minus above number)
Answer: 6*5*4*1 + 5*5*4*3 = 420.
Related Threads on Counting Problems
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
