Couple of Dynamic Questions
  1. Jan 12, 2005 #1
    Boredom...
    I'm just plain stupid... (Don't know which equations to use...)
    If a 256 kg spacecraft weights 436 newtons when it is on the moon, what is the gravitational field strength (in N/kg) there?
    To slide a 9.0 kg object at constant speed along the ground requires a force of 14.3 N. What is the coefficient of friction?
    You are pulling a 50 kg mass over a rough surface of friction coefficient µ = 0.15 and you are pulling the mass using a spring of force constant = 200 N/m. How much would the spring stretch?
    How much does a 55 kg girl compress the spring in a pogo stick when she stands on it? You are given that the spring constant is 78 N/cm.
  3. Jan 12, 2005 #2
    Curious3141
    You should post any ideas you have. I'm sure you've studied *some* equations, otherwise you wouldn't need to be doing these.
  4. Jan 12, 2005 #3
    Curious3141
    So what you're saying is that you're expected to solve all these questions without having ANY knowledge of the first thing about dynamics ? Because that's the impression you're trying to sell.
    It's weak, dude. Unless you show that you've taken some effort, you'll get no help here.
  5. Jan 12, 2005 #4
    I would divide 436 N by 256 Kg = 1.703 N/Kg, unless you need to include the gravity for the moon.
    I would start off with µ = Fn/Ff
    Fn = 9.0 * 9.8 = 88.2
    Ff = 14.3 N
    Then solve the equation as, µ = 88.2/14.3 = 6.17
    As far for now...
    [tex] \mu = \frac {FN} {Ff}[/tex]
  6. Jan 12, 2005 #5
    Curious3141
    This answer and method is correct. You don't need to do anything more.
    Your equation for [itex]\mu[/itex] is the wrong way around. Try solving it again, it should be less than one.
    Use the same principles as in the previous question to find the kinetic frictional force resisting motion. Use Hooke's law [itex]F = kx[/itex] where k is given in the problem to determine [itex]x[/itex], the extension.
    What is the weight of the girl in Newton ? Use Hooke's law again.
  7. Jan 12, 2005 #6
    Yes I got it now, µ = Fn/Ff
    µ = 14.3/88.2 = 0.16
    (Thanks for telling me that the coefficient has to be less than 1)
    Ff = µFn
    Ff = (0.15)(490)
    Ff = 73.5
    F = kx
    x = F/k
    x = 73.5/200
    x = 0.3675 m, 36.75 cm
    55 kg girl = 539 N
    F = kx
    x = F/k
    x = 539/78
    x = 6.91 cm
  8. Jan 12, 2005 #7
    Curious3141
    Yup, they all look right. :smile:
  9. Jan 13, 2005 #8
    HallsofIvy
    You did the calculation correctly but the formula is μ= Ff/Fn.
