Tennis Ball: Force, Weight, G-Force & Acceleration at 200 km/h
  • Thread starter t1000ct
  • Tags
    Couple
In summary: GSince this value is closest to 500 G, the correct answer is 517.2 G.For the last part of the problem, we need to find the time it takes for the tennis ball to accelerate from 0-100 km/h when served at 200 km/h. Again, we can use the equation v = u + at, but this time we need to solve for t:t = (v-u)/aWhere:v = final velocity = 100 km/h = 27.78 m/su = initial velocity = 0 m/sa = acceleration = 5063.799 m/s^2Plugging these values into the equation
t1000ct
When served at 200 km/h (124 mph), what is the equivalent weight exerted on the tennis ball?
15 kg
162 kg
200 kg
320 kg
How much G-Force must a tennis ball sustain when served at 200 km/h (124 mph)? (for example the G-Force when flying a jet = 8G)
3G
50G
220G
1400G
How fast does a tennis ball accelerate from 0-100 km/h (62 mph) when serving at 200 km/h (124 mph)?
2.5 sec
3/10 sec
7/100 sec
4/1000 sec
Mass of a tennis ball = 56-59.6 grams so I used the mid point (57 grams)
200 km/h = 55 m/s
distance covered by the tennis ball is 0.6096 meters
f=ma
a = change in time x change in velocity
Don't know what to use for 3, formula for distance?
(1) I thought that the speed given is velocity and found it to be 5063.799 m/s
Force = 288.64 N and the weight exerted = 29.433 kg, which isn't any of the answers
also did 55.56(.057) = 3.692 N and it doesn't match any of the answers
(2) I just did f=ma and got 3.2 and i thought that this was the answer since it is close to 3G but I'm not sure if I'm right or not
(3) I honestly have no idea how to do this. I took Honors Physics as a Junior in HS and now I'm a freshman in college and I don't remember any of this.
Thanks!
Hello!
To solve this problem, we need to use the equations of motion, specifically the one that relates acceleration, initial velocity, final velocity, and time:
v = u + at
Where:
v = final velocity
a = acceleration
t = time
For the first part of the problem, we need to find the weight exerted on the tennis ball when served at 200 km/h. The weight exerted is the same as the force acting on the ball, so we can use the formula F = ma, where F is the force, m is the mass, and a is the acceleration.
Using the given information, we can find the acceleration by rearranging the equation above:
a = (v-u)/t
Where:
v = final velocity = 200 km/h = 55.56 m/s
t = time = 0.6096/55.56 = 0.010986 seconds
Plugging these values into the equation, we get:
a = (55.56-0)/0.010986 = 5063.799 m/s^2
Now, we can plug this value into the formula F = ma to find the force:
F = (0.057 kg)(5063.799 m/s^2) = 291.65 N
This is the force exerted on the tennis ball when served at 200 km/h. However, the question asks for the weight exerted, which is equal to the force divided by the acceleration due to gravity (9.8 m/s^2). So, the weight exerted on the tennis ball is:
W = 291.65 N / 9.8 m/s^2 = 29.73 kg
Since this value is closest to 30 kg, the correct answer is 29.73 kg.
For the second part of the problem, we need to find the G-Force experienced by the tennis ball when served at 200 km/h. G-Force is a measure of acceleration, so we can use the same formula as before to find the acceleration:
To find the G-Force, we need to divide this value by the acceleration due to gravity:
G-Force = 5063.799 m/s^2 / 9.
1. What is the force exerted on a tennis ball when hit at 200 km/h?
The force exerted on a tennis ball when hit at 200 km/h is approximately 51.5 Newtons.
2. What is the weight of a tennis ball?
The weight of a tennis ball is approximately 57 grams or 0.057 kilograms.
3. How does the force of a tennis ball change with increasing speed?
The force of a tennis ball increases with increasing speed. This is because the kinetic energy of the ball increases, resulting in a greater force upon impact.
4. What is the G-force experienced by a tennis ball when hit at 200 km/h?
The G-force experienced by a tennis ball when hit at 200 km/h is approximately 51.5 Gs. This is calculated by dividing the force exerted on the ball by the force of gravity (9.8 m/s^2).
5. How does the acceleration of a tennis ball change with increasing speed?
The acceleration of a tennis ball decreases with increasing speed. This is because as the speed increases, the air resistance also increases, resulting in a decrease in acceleration.
