Can light be trapped forever between two perfect mirrors?
In summary, if the sun suddenly collapsed into a black hole, it would take 8.5 minutes for us to stop seeing it. However, this would not change the gravitational pull on Earth. If the sun was instantly replaced by a black hole of the same volume, it would take 8 minutes for us to notice the change in gravity. As for the hypothetical scenario of bouncing a laser beam between two perfect mirrors, it is possible for the beam to maintain its speed and direction, but it would remain invisible unless it interacted with the air.
maniaciswicke
1. If gravity waves travel at the speed of light and it take about 8.5 minutes for to reach Earth from the sun, If the sun suddenly collapsed into a black hole would it take 8.5 minutes for us to start being pulled in?
2. If you could somehow set up 2 mirrors facing each other than reflected 100% of light. And if you could aim a laser pointer beam into one of the mirrors and take it away before the light bounced back to it,could the beam of light keep going back and forwards at the speed of light between the mirrors and maintain a beam of light in the air?
just couple of random things i was thinking about :)
1. If the sun suddenly collapsed into a black hole, nothing would happen except that we would stop seeing the sun. The mass of the sun does not change whether it is a black hole or not, so there is nothing that can pull us in more than the sun is doing right now already.
i know its a bad example because extra matter can't just appear in the sun
maybe if the sun was instantly replaced by a black hole of the same volume (with much larger mass)
i know its impossible but just interested with the speed of gravity as such
It's not gravity that travels at the speed of light (gravity is just there, it does not travel), but rather changes in gravity. So yes, if the sun would suddenly get twice as massive, it would take us 8 minutes to notice that. Likewise, if the sun would suddenly disappear, it would take us 8 minutes to realize it had gone (visually and 'gravitationally').
kk yeah that's wat i meant lol
2. Obviously impossible, but if you want to make the assumption that you have perfect mirrors, then yes. However, unless the laser beam interacts with the air (which invariably reduces the strength of the beam), it will remain invisible (unless you stick your eye in the reflecting path).
1. What is the purpose of asking "couple of random questions"?
The purpose of asking "couple of random questions" is often to gather information or insights from someone on a variety of topics or to break the ice in a conversation.
2. How do you come up with "couple of random questions"?
One can come up with "couple of random questions" by brainstorming, using prompts or prompts generators, or simply asking spontaneous questions that come to mind.
3. Are "couple of random questions" useful in research?
Yes, "couple of random questions" can be useful in research as they can provide unexpected insights or perspectives on a topic and can help researchers gather a wide range of information from different sources.
4. What are the benefits of asking "couple of random questions"?
Asking "couple of random questions" can help build rapport and create a more relaxed atmosphere, encourage critical thinking and creativity, and provide a diverse range of perspectives on a topic.
5. Can "couple of random questions" be used in team-building activities?
Yes, "couple of random questions" can be used in team-building activities to help team members get to know each other better, promote open communication and collaboration, and foster a sense of trust and camaraderie within the team.
  • Aerospace Engineering
  • Quantum Physics
