Coursework - Water in guttering
In summary, the conversation is about a student asking for help with their physics coursework on investigating energy loss due to friction in water traveling along a piece of guttering. They are concerned about the complexity of the equations and the various factors that could affect the results. Another person suggests that the project may be too complicated and offers alternative ideas.
ms3
Hi
For my physics coursework I want to investigate the energy lost due to friction when water travels along an piece of guttering.
However there seem to be many different and complex equations for this, which seems to depend of the type of flow etc etc
Could anyone help by telling me if this is even possible? and if so how could you calculate it?
thanks a lot
Welcome to PF!
Hi ms3! Welcome to PF! :smile:
Sound horribly complicated …
depends on the depth of the water, the cross-section of the gutter, and the slope, among other things …
and modern plastic guttering even sags slightly between supports …
I'd do something else :wink:
1. What is the purpose of guttering?
Guttering is a system of channels that are installed along the edge of a roof to collect rainwater and direct it away from the building. The main purpose of guttering is to protect the foundation of a building from water damage by preventing water from pooling around the base of the structure.
2. How does water flow through guttering?
Water flows through guttering by the force of gravity. The channels are typically sloped downward towards a downspout, which directs the water towards a drain or a designated area away from the building.
3. What materials are commonly used for guttering?
The most common materials used for guttering are aluminum, vinyl, copper, and galvanized steel. Each material has its own advantages and disadvantages, such as durability, cost, and appearance.
4. How do clogged gutters affect water flow?
Clogged gutters can significantly impact water flow by preventing proper drainage. Leaves, debris, and other materials can accumulate in the gutters and block water from flowing through, causing it to overflow and potentially damage the building's foundation or surrounding landscape.
5. How often should guttering be maintained?
Guttering should be regularly maintained at least twice a year, typically in the spring and fall. However, if the building is surrounded by trees or experiences heavy rainfall, more frequent maintenance may be necessary to prevent clogs and ensure proper water flow.
  • Classical Physics
  • Thermodynamics
  • Mechanical Engineering
