Covariant derivative of tangent vector for geodesic
In summary: The covariant derivative is written as ##\nabla_V## because it is a vector. It is important to remember that covariant derivatives are written in the same form whether the vectors are normalized or not.
Apashanka
429
For the simple case of a 2-D curve in polar coordinated (r,θ) parametrised by λ (length along the curve).
At any λ the tangent vector components are V1=dr(λ)/dλ along ##\hat r## and V2=dθ(λ)/dλ along ##\hat θ##.
The non-zero christoffel symbol are Γ122 and Γ212.
From covariant derivative
(1)∇1V1=∂rV1
(2)∇2V2=∂θV2212V1.
(3)∇2V1=∂θV1122V2
(4)∇1V2=∂rV2212V2
For this curve to be geodesic V1=1 and V2=0
And (1),(3) and (4) becomes 0 and (2)≠0.
But for a geodesic the covariant derivatives of tangent vectors are 0.
Am I missing something??
I am trying to interpret physically by taking these examples.
Thank you
No, for a geodesic the covariant derivative of the tangent vector in the direction of the tangent vector is zero. In your case, the direction of the tangent vector is the 1-direction.
Ohh that means sir here in this case ∇1V1 and ∇1V2 has to be necessarily 0.(for geodesic)
Sir what could be the physical meaning behind these zero and non-zero terms of these covariant derivative ...as I am taking these simple examples to learn.
Thank you
(1)∇1V1=∂rV1
(2)∇2V2=∂θV2212V1.
(3)∇2V1=∂θV1122V2
(4)∇1V2=∂rV2212V2
Thank you
The same curve parametrised by λ in 2-D cartesian coordinate system and if this curve is geodesic.(straight line with slope m).
x(λ)=λ/√(1+m2) and y(λ)=mλ/√(1+m2) .therefore the tangent vector components at any λ becomes V1≠f(λ) along ##\hat x## and V2≠f(λ) along ##\hat y##.
Which is consistent that the tangent vector is fixed in direction throughout the curve (as taken geodesic).
Now the tangent vector direction is ##\hat n=\frac{\hat x+m\hat y}{\sqrt(1+m^2)}## and the tangent vector is given as V=V1(≠λ)##\hat x+##V2(≠λ)##\hat y##
From the covariant derivative ##\nabla_{\hat n}V=0##,
My question is sir how to prove it ??
For polar coordinates it is easy
In 2D, Cartesian Coordiantes, the parameters are given by ##(x(\lambda), y(\lambda)) = (a_1 \lambda + b_1, a_2 \lambda + b_2)## and the tangent vector components are ##(a_1,a_2)## at any point with coordinates ##(x,y)##. This tangent vector can also be expressed as ##a_1 e_x + a_2 e_y \equiv V##. Then, $$\nabla_V V = V^\mu \nabla_\mu (V^\nu e_\nu) = V^\mu (\partial_\mu V^\nu) e_\nu = 0$$
Likes Apashanka
Will you please elaborate your last step I didn't get it...
In flat spaces, using cartesian coordinates, ##\nabla_\mu = \partial_\mu## and ##\partial_\mu e_\nu = 0##, and since ##V^\nu## are just constants, ##\partial_\mu V^\nu = 0##. Does that clear up your confusion?
It's ok ,my question is why ##\nabla_V## is written as ##V^\mu \nabla_\mu##
That’s how you take derivatives (covariant or otherwise) along an arbitrary curve.
Okk for this it is the covariant vector along the tangent vector ,but for any arbitrary direction will it be same??
The definition of ##\nabla_\mu## is ##\nabla_{\partial_\mu}## and the connection is linear in the direction (note that ##\partial_\mu## is a basis vector of the tangent space). Hence, for an arbitrary vector ##V = V^\mu \partial_\mu##, you find
\nabla_V = \nabla_{V^\mu \partial_\mu} = \{\mbox{linearity}\} = V^\mu \nabla_{\partial_\mu} \equiv V^\mu \nabla_\mu.
Likes Pencilvester
For any vector ##V=V^\mu e_\mu## .
Therefore ##e_\mu=∂_\mu##??
You can choose whatever basis you like, but if you want to express the covariant derivative in terms of ##\nabla_\mu \equiv \nabla_{\partial_\mu}##, then you must use the coordinate basis.
I'm not sure that @Orodruin's notation is familiar to you. I know, I never completely got used to it.
A vector ##V## uniquely determines an operator on scalar fields: ##V(\phi) \equiv V^\mu \partial_\mu \phi##. Because of this, the modern way of teaching differential geometry simply defines a vector to be a differential operator on scalar fields. So we let it be an equality:
Once you've identified a vector with the corresponding differential operator, it follows that for the basis vectors ##e_\mu##:
##e_\mu = \partial_\mu##
(That is, when ##e_\mu## is the basis vector corresponding to the coordinate ##x^\mu##).
I would add that this is actually very natural. In curvilinear coordinates in Euclidean space you typically introduce the tangent vector basis as the partial derivatives of the position vector with respect to the coordinates. However, the position vector never actually does anything there, it kind of just comes along. Once in a general manifold there is anyway no longer any notion of a position vector so the most elegant solution is to realize that it was never needed and you can just get rid of it.
1. What is the definition of a covariant derivative of a tangent vector for a geodesic?
The covariant derivative of a tangent vector for a geodesic is a mathematical tool used in differential geometry to measure the change of a vector along a curved path on a manifold. It takes into account the curvature of the manifold and ensures that the vector remains tangent to the geodesic at each point.
2. How is the covariant derivative of a tangent vector calculated?
The covariant derivative of a tangent vector is calculated using the Christoffel symbols, which represent the connection between the tangent space and the manifold. These symbols are used to construct a formula that takes into account the curvature of the manifold and the change in the vector along the geodesic.
3. What is the significance of the covariant derivative of a tangent vector for geodesics?
The covariant derivative of a tangent vector is important in the study of geodesics because it allows us to define and measure the change in a vector along a curved path on a manifold. This is essential for understanding the behavior of particles or objects moving along geodesics in curved spacetime.
4. How does the covariant derivative of a tangent vector relate to parallel transport?
The covariant derivative of a tangent vector is closely related to parallel transport, which is the process of moving a vector along a curve while keeping it parallel to itself. The covariant derivative measures the change in the vector as it is parallel transported along a geodesic, and ensures that it remains tangent to the geodesic at each point.
5. Can the covariant derivative of a tangent vector be used in other areas of physics?
Yes, the covariant derivative of a tangent vector has applications in many areas of physics, including general relativity, electromagnetism, and quantum mechanics. It is a fundamental tool in understanding the behavior of particles and fields in curved spacetime and is essential for making predictions and calculations in these areas.
  • Differential Geometry
