Understanding Covariant Derivative: d Explained
In summary, the covariant derivative is a way to take derivatives on a curved manifold. It involves adding a correction term, represented by the connection, to the partial derivative. The indices in the equation represent the dimensions of the manifold, and the connection is an n x n matrix that corrects the partial derivative for each component of the vector.
TromboneNerd
I get in essence what the covariant derivative is, and what it does, but I am having trouble with the definition, of all things.[tex]\nabla_{\alpha}T^{\beta\gamma}=\frac{\partial{T^{\beta\gamma}}}{\partial{x^{\alpha}}}+\Gamma^{\beta}_{d\alpha}T^{d\gamma}+\Gamma^{\gamma}_{d\alpha}T^{\beta d}[/tex]
Im good with everything except d. what is it? where did it come from? its just tacked into the formula but i don't understand what it is. any help would be greatly appreciated
Have you learned Einstein's summation convention yet? You just sum over all values for d.
Whenever, an index is repeated with one as an upper index and one as a lower index, the understanding is to sum over all possible values of that index.
yes i am familiar with the summation convention, but is it assumed to be basic three dimensional euclidean space? so
[tex]\nabla_{\alpha}T^{\beta\gamma}=\sum_{i=1}^{3}\frac{\partial{T^{\beta\gamma}}}{ \partial{x^{\alpha}}}+\Gamma^{\beta}_{d^{i}\alpha}T^{d^{i}\gamma}+\Gamma^{\gamma}_{d^{i}\alpha}T^{\beta d^{i}}[/tex]
where d1 d2 d3 each represent a different spatial dimension? or is it
[tex]\nabla_{\alpha}T^{\beta\gamma}=\sum_{d=1}^{n}\frac{\partial{T^{\beta\gamma}}}{ \partial{x^{\alpha}}}+\Gamma^{\beta}_{d\alpha}T^{d\gamma}+\Gamma^{\gamma}_{d\alpha}T^{\beta d}[/tex]
where d itself is summed over, and if so, what determines n? the number of indices in the tensor? I don't see why you would insert 1,2...n into the equation where the d's are if this is the case. they don't seem like they are operating as coefficients. could you please go into further detail?
Should be:
[tex]
(\nabla_{\alpha}T)^{\beta\gamma}=\frac{\partial{T^{\beta\gamma}}}{\partial{x^{\alpha}}}+\Gamma^{\beta} _{\alpha \sigma}T^{\sigma\gamma}+\Gamma^{\gamma}_{\alpha \sigma}T^{\beta \sigma}
[/tex]
The above means: for every three fixed indices [tex]\alpha,\beta,\gamma[/tex], for instance (in 3 dimensions)
for [tex]\alpha=2,\beta=3,\gamma=2[/tex], we compute:
[tex]
( \nabla_{2}T)^{32}=\frac{\partial T^{32}}{\partial x^{2}} +\sum_{\sigma=1}^3\Gamma^{3}_{2 \sigma}T^{\sigma 3}+\sum_{\sigma=1}^3\Gamma^{2}_{2 \sigma}T^{3 \sigma}
[/tex]
[tex] ( \nabla_{2}T)^{32}[/tex] should read: (32) component of the tensor [tex]\nabla_{2}T[/tex]. Usually it is written without parenthesis as [tex]\nabla_{2}T^{32}[/tex] but it is good to keep parenthesis in mind. It is not the covariant derivative of the component of the tensor, but it is a component of the covariant derivative of the tensor.
Neither of the expressions in #3 makes sense, since you have an extra index (c) on the right that isn't being summed over and doesn't appear on the left.
All the indices run from 1 to n where n is the number of dimensions of the manifold, unless the manifold is the spacetime of special or general relativity. In those cases, the convention is to have the indices run from 0 to 3 instead of from 1 to 4.
You shouldn't use greek letters for some of the indices and latin letters for others, because a different type of letter than the one you use for most indices usually means that it's not just another index. For example, in relativity, one convention that many people use is to have greek indices run from 0 to 3, and latin indices from 1 to 3.
@Fredrik
I was correcting my expression several times. Also changed summation index to Greek one - as you have indicated. In principle it can be anything, but better not to mix Greek and Latin, small and capital etc.
I wrote all of that before I saw your post. My comments were about the expressions in post #3.
that c should be an alpha. i changed it and it should be correct now. I wrote it on paper before that with c so i got myself a little mixed up.
I've visited this thread several times, without comprehending the nature of your stumbling-block. Now, I may understand.
Consider just the covariant derivative of a vector to keep things simple.
[tex]\nabla_{\mu}V^{\nu} = \partial_{\mu} V^{\nu} + \Gamma_{\mu}^{\nu}_{\lambda}V^\lambda[/tex]
Rewrite this as
[tex]\nabla_{\mu}V^{\nu} = \partial_{\mu} V^{\nu} + (\Gamma_{\mu})^{\nu}_\lambda}V^\lambda[/tex]
Take one dimension at time. For example,
[tex]\nabla_{1}V^{\nu} = \partial_{1} V^{\nu} + (\Gamma_{1})^{\nu}_{\lambda}V^\lambda[/tex]
For each dimension in which we take a derivative, in this case the x1 direction. The connection is a correction to the derivative of the vector component in the x1 direction. It's just an n x n matrix that takes each component of the vector and gives a correction for this component.
Sean Carroll, Lecture Notes on General Relativity, does a much better job of this, available online, page 56, for a far more lucid explanation.
1. What is a covariant derivative?
A covariant derivative is a mathematical concept used in differential geometry to describe the rate of change of a vector or tensor field along a given direction in a curved space. It takes into account the curvature of the space and ensures that the derivative is consistent with the underlying geometry.
2. How is the covariant derivative different from the ordinary derivative?
The covariant derivative is specifically designed for use in curved spaces, while the ordinary derivative is used in flat, Euclidean spaces. The covariant derivative takes into account the curvature of the space, while the ordinary derivative assumes a flat space.
3. What does the "d" notation represent in the covariant derivative?
The "d" notation represents the infinitesimal change in a given direction. It is used to differentiate between different directions in a curved space and is essential for calculating the covariant derivative.
4. How is the covariant derivative related to the Christoffel symbols?
The Christoffel symbols are used to describe the connection between the local coordinates in a curved space. The covariant derivative can be written in terms of the Christoffel symbols and is used to calculate the derivative of a vector or tensor field in a given direction.
5. What are some practical applications of understanding the covariant derivative?
The covariant derivative is used extensively in fields such as general relativity, differential geometry, and mathematical physics. It is crucial for understanding the behavior of physical quantities in curved spaces and is used in many practical applications, including the study of black holes, gravitational waves, and cosmology.
  • Differential Geometry
