Homework Help: Creating memory for array
  1. Sep 10, 2014 #1
    1. Using new to create a memory block for a static array of strings. How to know the number of strings in an array of strings
    2. Relevant equations
    new
    3. The attempt at a solution
    1. static char ** array=new char*[]; // why the empty [] ? Will I get a minus point if coding like this ? My teacher says subscript data should be known in advance
    2. If I have a library function that has the signature
    PHP:
    char** doSomething(...);
    I am using it like this
    PHP:
    char**ret=doSomething();
    I then would like to know the number of strings returned from that function.
    I am taking the first course in IT programming, I chose C++ language.
  3. Sep 11, 2014 #2
    jedishrfu
    Staff: Mentor
    I think you have to count them until the pointer is a null.
    You could use a while loop and increment a counter while the ret pointer != NULL.
  4. Sep 11, 2014 #3
    rcgldr
    Since the problem statement mentions "static" array of strings, then I assume it's a fixed number of strings, and that's it's an array of pointers to the first characters of a set of strings. The function could include a parameter that would be a pointer or a reference to a string count that the function sets. There could also be a parameter to return the pointer to the array, or it could be a return value. Note that a static variable's name scope is local, but it's duration is for the entire time a program (thread) is running, so it should be safe to return a pointer to a static variable in a function. Since these are static arrays, there's no need for new (I chose as to represent array of strings):
    static char * as[4] = {"one", "two", "three", "four"};
    optionally if using a null pointer to indicate the end of an array:
    static char * as[5] = {"one", "two", "three", "four", (char *)0};
    or an array with all null pointers:
    static char * as[5];
Have something to add?
Draft saved Draft deleted
