Creating postfix calc
  • Thread starter ali11
ali11
can somebody help. i m getting following errors. i m creating postfix calc
C:\Users\Hamza\Pictures\CalcGUIPanel.java:204: int cannot be dereferenced
Integer arg2=resultValue.pop();
C:\Users\Hamza\Pictures\CalcGUIPanel.java:205: int cannot be dereferenced
resultValue.push(resultValue.pop()+arg2);
C:\Users\Hamza\Pictures\CalcGUIPanel.java:205: operator + cannot be applied to <any>,java.lang.Integer
C:\Users\Hamza\Pictures\CalcGUIPanel.java:211: int cannot be dereferenced
C:\Users\Hamza\Pictures\CalcGUIPanel.java:212: int cannot be dereferenced
resultValue.push(resultValue.pop()-arg2);
C:\Users\Hamza\Pictures\CalcGUIPanel.java:219: int cannot be dereferenced
C:\Users\Hamza\Pictures\CalcGUIPanel.java:220: int cannot be dereferenced
resultValue.push(resultValue.pop()*arg2);
C:\Users\Hamza\Pictures\CalcGUIPanel.java:227: int cannot be dereferenced
C:\Users\Hamza\Pictures\CalcGUIPanel.java:228: int cannot be dereferenced
13 errors
Tool completed with exit code 1
Code:
import java.util.Stack;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import javax.swing.event.*;
import java.util.Scanner;
public class CalcGUIPanel extends JPanel
//--\- Component referenced during execution
 private JTextField displayField; // display result / input.
 //--\- Variables representing state of the calculator
 private boolean startNumber = true; // true: num key next
 private int resultValue = 0; // result so far
 private String previousOp = "="; // previous operation
 Stack<String> cStack=new Stack<String>();
 public CalcGUIPanel()
 //--\- Display field
 displayField = new JTextField();
JButton clearButton = new JButton("CLEAR");
clearButton.addActionListener(new ClearListener());
 //--\- One listener for all numeric keys.
 ActionListener numListener = new NumListener();
 //--\- Layout numeric keys in a grid. Generate the buttons
 // in a loop from the chars in a string.
 String buttonOrder = "789456123 0 ";
 JPanel buttonPanel = new JPanel(new GridLayout(5, 3));
 for (int i = 0; i < buttonOrder.length(); i++) {
 String keyTop = buttonOrder.substring(i, i+1);
 if (keyTop.equals(" ")) {
 buttonPanel.add(new JLabel(""));
 } else {
 JButton b = new JButton(keyTop);
 b.addActionListener(numListener);
 buttonPanel.add(b);
 //--\- One ActionListener to use for all operator buttons.
 ActionListener opListener = new OpListener();
 //--\- Create panel with gridlayout to hold operator buttons.
 // Use array of button names to create buttons in a loop.
 JPanel opPanel = new JPanel(new GridLayout(5, 1));
 String[] opOrder = {"+", "-", "*", "/", "enter"};
 for (int i = 0; i < opOrder.length; i++) {
 JButton b = new JButton(opOrder[i]);
 cStack.push(opOrder[i]);
 b.addActionListener(opListener);
cStack.push("1");
cStack.push("2");
cStack.push("3");
cStack.push("4");
cStack.push("5");
cStack.push("6");
cStack.push("7");
cStack.push("8");
cStack.push("9");
cStack.push("0");
 cStack.push("+");
  cStack.push("-");
  cStack.push("*");
  cStack.push("/");
  cStack.push("enter");
 opPanel.add(b);
 //--\- Layout the top-level panel.
 this.setLayout(new BorderLayout());
 this.add(displayField, BorderLayout.NORTH );
 this.add(buttonPanel , BorderLayout.CENTER);
 this.add(opPanel , BorderLayout.EAST );
this.add(clearButton , BorderLayout.SOUTH );
 }//end constructor
 //====================================================== action_clear
 /*\* Called by Clear btn action listener and elsewhere.*/
 private void action_clear() {
 startNumber = true;
 displayField.setText("0");
 resultValue = 0;
 int arg2;
 previousOp = "=";
 // inner listener class OpListener
 /*\* Listener for all op buttons. \*/
 class OpListener implements ActionListener {
 public void actionPerformed(ActionEvent e) {
 // The calculator is always in one of two states.
 // 1. A number must be entered \-\- this operator is wrong.
 // 2. An operator must be entered \-\- we're ok.
 if (startNumber) { // Error: needed number, not operator
 action_clear();
 displayField.setText("ERROR");
 } else {
 startNumber = true; // Next thing must be a number
try {
 String displayText = displayField.getText();
 int currentValue = Integer.parseInt(displayText);
 if (previousOp.equals("=")) {
 cStack.push(resultValue + "");
  else if (previousOp.equals("+")) {
 }  else if (previousOp.equals("-")) {
 } else if (previousOp.equals("*")) {
 } else if (previousOp.equals("/")) {
	cStack.pop().equals("/");
 displayField.setText("" + resultValue);
 } catch (NumberFormatException ex) {
 action_clear();
 displayField.setText("Error");
 //--\- set \_previousOp for the next operator.
 previousOp = e.getActionCommand();
 }//endif \_startNumber
 }//endmethod
 }//end class
 //////////////////////////////////// inner listener class ClearListener
 // Action listener for numeric keys
 class NumListener implements ActionListener {
 String digit = e.getActionCommand(); // Get text from button
 if (startNumber) {
 // This is the first digit, clear field and set
 displayField.setText(digit);
 startNumber = false;
 } else {
 // Add this digit to the end of the display field
 displayField.setText(displayField.getText() + digit);
 }//end class
 //inner listener class ClearListener
class ClearListener implements ActionListener {
action_clear();
Answers and Replies
phinds
Insights Author
2021 Award
17,914
10,109
you are more likely to get help if you say WHAT you want help with. There are a LOT of posts on this site and nearly ALL of them are because someone needs help, so "needs help" is a pretty useless subject line.
ali11
i already explain what i need help with in my post.
phinds
Insights Author
2021 Award
17,914
10,109
So I take it you think that everyone here reads every post? Dream on.
ali11
dude instead of argue can u just answer my question
phinds
Insights Author
2021 Award
17,914
10,109
No, I don't HAVE an answer to your question. I was trying to help you GET an answer to your question, but you seem to be missing the point.
willem2
2,088
347
resultvalue is an integer, wich is primitive object wich can't have any methods such as pop().
pop() should be used on a stack object, and shouldn't there be some stack object besides cstack to hold intermediate results?
ali11
so where should i use pop method.i m sorry this is my 1st time i m using stack.
willem2
2,088
347
you must apply the push and pop method to a stack.
arg1 = cstack.pop()
arg2 = cstack.pop()
resultvalue = arg1 + arg2
cstack.push(resultvalue)
8,280
arg1 = cstack.pop()
arg2 = cstack.pop()
To the OP: For this code to work, two values must have been previously pushed onto the stack. The pop method throws EmptyStackException if you try to pop a stack that is empty.
Suggested for: Creating postfix calc
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
