Cross Product and Dot Product
  • Thread starter ND3G
ND3G
81
Use two methods to determine a unit vector perpendicular to both (2,1,-3) and (-1, 7, 4)
Using Cross Product:
Let v be a perpendicular vector to the given vectors
v = a*b
= (2,1,-3)(-1,7,4)
=((1)(4)-(7)(-3), (-3)(-1)-(4)(2), (2)(7)-(-1)(1))
=(4+21, 3-8, 14+1)
=(25, -5, 15)
= (5, -1, 3)
= |(5,-1, 3)|
= sqr(25+1+9
=sqr(35)
Let u be a unit vector in the direction of (5, -1, 3)
u = v/|v| = 1/sqr(35)(5, -1, 3) = (5/sqr(35), -1/sqr(35), 3/sqr(35))
Using dot product:
Let p = (x, y, z) represent the vector that is perpendicular to the vectors.
a = (2, 1, -3) and b = (-1, 7, 4)
Then p*a = 0 and p*b = 0
(x, y, z)(2, 1, -3) = 0 and (x, y, z)(-1, 7, 4) = 0
2x + y - 3z = 0
-x + 7y + 4Z = 0
Isolate x in equation (1) to get x = -y/2 + 3z/2
Substitute this into equation (2)
-(-y/2 + 3z/2) + 7y +4z = 0
y/2 - 3z/2 +7y +4z = 0
z = 0 --> substitute into equation (1) gives 2x + y = 0 and so x = -y/2
If you let x = 1, then y = -2
Therefore p = (x, y, z) = (1, -2, 0), which gives a different vector from the one found using cross product.
Determine the magnitude of this vector and then find a unit vector as required.
|(1, -2, 0)| = sqr(1+4) = sqr(5)
Let u be a unit vector in the direction of (1, -2, 0)
u = v/|v| = 1/sqr(5)(1, -2, 0) = (1/sqr(5), -2/sqr(5), 0)
The two answers should match up but they don't and I am not sure what I am doing wrong. I have been over it a number of times but I just can not see where the error lies. Any help would be greatly appreciated
Answers and Replies
ND3G
81
You can substitute in any value for z, however 0 would be the only value that would isolate x and y. At least that is how I understand it from the sample equations.
D H
Staff Emeritus
Insights Author
15,450
687
2x + y - 3z = 0
-x + 7y + 4Z = 0
You had it correct to this point. These are two equations in three unknowns. One solution is the trivial solution, x=y=z=0. There are an infinite number of other solutions because two equations in three unknowns do not yield a unique solution.
You cannot arbitrarily set one of the variables (say z) to zero because then you will find that the other two variables (x and y) must also be zero. This is the trivial solution, and it is the one solution you do not want.
What you can do is to express any two of the variables in terms of the third. For example, find a way to express x and y in terms of z. There is an implied third equation: The desired vector is a unit vector. You can use this to come up with a value for z and hence for x and y. Note: the sign of the value for z will be arbitrary, as the unit vector equation will result in something like [itex]z^2 = a[/itex]. You will get identical results if you choose x or y as the basis variable instead of z.
ND3G
81
I'm sorry but I have been staring at this question for close to three hours now and I still no closer to resolving it as when I started.
How exactly is the fact that the vector is a unit vector going to help me determine a value for z?
Office_Shredder
Staff Emeritus
2021 Award
5,215
1,165
Basically, it means try to solve it again, only this time without z=0. You'll get a vector that looks something like
(z+2, 3z, z) (I didn't actually work it out, but it should have one independent parameter).
You then have to normalize this by finding a value of z such that the sum of the square of the terms equals one
D H
Staff Emeritus
Insights Author
15,450
687
You started with a general form for the normal vector [itex]\vec n = (x,y,z)[/itex] and then developed two equations for [itex]x,y,z[/itex]. From those two equations, you should be able to reduce those equations to something of the form [itex]x=a*z, y=b*z[/itex] where [itex]a[/itex] and [itex]b[/itex] are constants. With this, the normal vector becomes [itex]\vec n = (a*z, b*z, z)[/itex].
You want this to be a unit vector. What is the inner product of a unit vector with itself? What is the inner product of [itex]\vec n[/itex] with itself?
D H
Staff Emeritus
Insights Author
15,450
687
This is not a three-hour problem. You had it right up to this point:
2x + y - 3z = 0
-x + 7y + 4Z = 0
Here is where you went wrong:
z = 0
What you should have done was to work with this equation:
combining terms,
15/2 y + 5/2 z = 0
or
y = -z/3
With this it should be obvious that choosing z=0 forces y (and hence x) to be zero as well. So choosing z=0 was exactly the wrong thing to do.
Can you finish with y=-z/3 (alternatively, z=-3y) and your equation for x in terms of y and z?
ND3G
81
Ok, I think I have the idea. z = -3y
x = -y/2 + 3(-3y)/2 = -10y/2 = -5y
Therefore, (-5y, y, -3y)
D H
Staff Emeritus
Insights Author
15,450
687
Excellent. Now finish it. You want a unit vector.
nrqed
295
Yes. And after normalizing to a unit vector, the "y" drops out completely.
Notice that what you get is exactly minus th evector you got from the other method so it's not the same vector! But that's ok because there are actually *two* unit vectors perpendicular to [itex] \vec{a} [/itex] and [itex] \vec{b} [/itex]. You found one by the first technique and you found the other one by the second technique
ND3G
81
Thanks for all the hand holding guys. I am doing this course by correspondence and sometimes the text is less than ideal.
Suggested for: Cross Product and Dot Product
  • Last Post
  • Last Post
  • Last Post
  • Last Post
