Cross products problem
  • Thread starter togame
togame
Find the magnitude of [itex]\vec{v} \times \vec{B}[/itex] and the direction of the new vector.
[itex]\vec{v}=\left \langle 0,0,20 \right \rangle[/itex]
[itex]\vec{B}=\left \langle 1,1,0 \right \rangle[/itex]
[itex]|\vec{v}|=\sqrt{0^2+0^2+20^2}=20[/itex]
[itex]|\vec{B}|=\sqrt{1^2+1^2+0^2}=\sqrt{2}[/itex]
I have found the magnitude as [itex]20\sqrt{2}[/itex] which I'm pretty sure is right. My main problem is the new angle.
For the angle I have [itex]sin\theta=\frac{|\vec{v} \times \vec{B}}{|\vec{v}||\vec{B}|}=\frac{20\sqrt{2}}{20\sqrt{2}}[/itex]
So the angle should be [itex]sin^{-1}(\frac{20\sqrt{2}}{20\sqrt{2}})[/itex]
But the angle listed as the answer is 135 degrees.
Solving backwards, [itex]|\vec{v}||\vec{B}|[/itex] would need to be 40 and I can't see where this comes from. Any input is greatly appreciated.
Answers and Replies
Dick
26,263
620
Yes, the magnitude is [itex]20\sqrt{2}[/itex]. Though I'm not really sure how you got that. But what angle are you looking for? The angle you are computing is the angle between the two vectors which is 90 degrees. I think they are looking for the angle the new vector makes with respect to the x-axis. To answer I think you need to actually calculate the vector ##\vec{v} \times \vec{B}##.
HallsofIvy
43,021
970
The direction of a vector in three dimensions cannot be given by a single angle.
Is "[itex]|u x v|= |u||v|sin(\theta)[/itex]" and "u x v is perpendicular to both u and v by the right hand rule" the only way you have to find u x v? If u= ai+ bj+ ck and v= di+ ej+ fk then u x v= (bf- ce)i+ (ce- af)j+ (ae- bd)k is often simpler to use.
Suggested for: Cross products problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
