• Support PF! Buy your school textbooks, materials and every day products Here!
Crossed ladder problem help
  • Thread starter kingredg
my teacher gave my class this problem earlier this week
and we need to know it by the end of next week
anyone knows how to solve this
sorry for the bad drawing
Answers and Replies
1,005
65
First, you can use the obvious Pythagorean theorem to get two equations in 3 unknowns. Get the third equation by using CF and the ratios of the two similar triangles to their larger counterparts.
^^^how can i use the Pythagorean theorem when i only have 1 side length for both
and by the way i'm only a freshman
what's the CF?
454
if you guess that AE = x. you can calculate AB and DE with pythagoras, and then
you have CF/AF = DE/AE because the triangles AED and AFC are similar. That gets you
AF, and you can find EF in the same way. Finally you must have AE = AF + EF.
I believe you'll get a 4th degree equation in x^2 after two rounds of squaring and collecting terms. I'm going to solve this numerically.
^^^i'll try that
97
Is AE [tex]\;\; \approx \;\,26\,\text meters\,?[/tex]
454
I get the solution of [tex] \frac {CF}{\sqrt{{AD}^2 - x^2}} + \frac {CF}{\sqrt{{BE}^2 - x^2}} = 1[/tex]
wich is 26.0328775442....
^^^sorry for asking such a dumb question but
how did you find the X to solve it
454
I just set AE equal to x. this gives you
DE = sqrt(AD*AD - x*x) using pythagoras in the triangle DEA
AF = CF * x / DE using the fact that CF/AF = DE/AE because the triangles AED and AFC are similar.
combined this gives [tex] AF = \frac {x(CF)}{\sqrt{{AD}^2 - x^2}} [/tex]
you can do the same on the other side to get [tex] EF = \frac {x (CF)}{\sqrt{{BE}^2 - x^2}} [/tex]
Finally you must have AF + EF = AE = x
Substituting the previous expressions for AF and EF in this and dividing by x gives:
[tex]
\frac {CF}{\sqrt{{AD}^2 - x^2}} + \frac {CF}{\sqrt{{BE}^2 - x^2}} - 1 = 0
[/tex]
The easiest way to solve this is to type 10/sqrt(1600-x^2)+10/sqrt(900-x^2)-1
into this webpage http://wims.unice.fr/wims/wims.cgi?session=6B26C0C5C3.3&+lang=en&+module=tool%2Fanalysis%2Ffunction.en" [Broken]
[tex]
[/tex]
i try plugging that into my calculator is it okay if i just press the x (variable) or do i have to have in a specific number
Related Threads for: Crossed ladder problem help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
