Solving the Crossed Ladder Problem
  • Thread starter kingredg
In summary, my teacher gave my class this problem earlier this week and we need to know it by the end of next week. Anyone know how to solve this?
kingredg
anyone knows how to solve this
sorry for the bad drawing
First, you can use the obvious Pythagorean theorem to get two equations in 3 unknowns. Get the third equation by using CF and the ratios of the two similar triangles to their larger counterparts.
^^^how can i use the Pythagorean theorem when i only have 1 side length for both
and by the way I'm only a freshman
what's the CF?
if you guess that AE = x. you can calculate AB and DE with pythagoras, and then
you have CF/AF = DE/AE because the triangles AED and AFC are similar. That gets you
AF, and you can find EF in the same way. Finally you must have AE = AF + EF.
I believe you'll get a 4th degree equation in x^2 after two rounds of squaring and collecting terms. I'm going to solve this numerically.
^^^i'll try that
Is AE [tex]\;\; \approx \;\,26\,\text meters\,?[/tex]
I get the solution of [tex] \frac {CF}{\sqrt{{AD}^2 - x^2}} + \frac {CF}{\sqrt{{BE}^2 - x^2}} = 1[/tex]
wich is 26.0328775442...
^^^sorry for asking such a dumb question but
how did you find the X to solve it
I just set AE equal to x. this gives you
DE = sqrt(AD*AD - x*x) using pythagoras in the triangle DEA
AF = CF * x / DE using the fact that CF/AF = DE/AE because the triangles AED and AFC are similar.
combined this gives [tex] AF = \frac {x(CF)}{\sqrt{{AD}^2 - x^2}} [/tex]
you can do the same on the other side to get [tex] EF = \frac {x (CF)}{\sqrt{{BE}^2 - x^2}} [/tex]
Finally you must have AF + EF = AE = x
Substituting the previous expressions for AF and EF in this and dividing by x gives:
[tex]
\frac {CF}{\sqrt{{AD}^2 - x^2}} + \frac {CF}{\sqrt{{BE}^2 - x^2}} - 1 = 0
[/tex]
The easiest way to solve this is to type 10/sqrt(1600-x^2)+10/sqrt(900-x^2)-1
into this webpage http://wims.unice.fr/wims/wims.cgi?session=6B26C0C5C3.3&+lang=en&+module=tool%2Fanalysis%2Ffunction.en"
[tex]
[/tex]
i try plugging that into my calculator is it okay if i just press the x (variable) or do i have to have in a specific number
What is the "Crossed Ladder Problem"?
The "Crossed Ladder Problem" is a mathematical problem where two ladders of equal length are leaning against each other at an angle, forming a cross. The goal is to find the height at which the ladders cross.
What is the formula for solving the "Crossed Ladder Problem"?
The formula for solving the "Crossed Ladder Problem" is h = (L1L2) / (L1 + L2), where h is the height at which the ladders cross, and L1 and L2 are the lengths of the two ladders.
What are the assumptions made in solving the "Crossed Ladder Problem"?
The assumptions made in solving the "Crossed Ladder Problem" are that the ladders are of equal length, they are leaning against each other at an angle of 90 degrees, and the ground is flat and level.
What are some real-world applications of the "Crossed Ladder Problem"?
The "Crossed Ladder Problem" has practical applications in fields such as architecture, engineering, and construction. It can be used to determine the height at which two ladders should cross to create a stable structure.
Is there a visual representation of the "Crossed Ladder Problem"?
Yes, there are visual representations of the "Crossed Ladder Problem" available online. These diagrams can help to better understand the problem and its solution.
  • Precalculus Mathematics Homework Help
