Cube-Rod Pendulum: Solving Homework Statement & Equations
  • Thread starter lilphy
  • Tags
    Pendulum
In summary: So the moment of inertia about an arbitrary axis isI= nIn = cos(a)2Ixx+cos(b)2Iyy+cos(c)2Izz unit vector n going from origin to the corner n=(Cos(a), cos(b), cos(c))
lilphy
28
Hello
I am studying for my exam and found an interesting exercise that I'm trying to solve
1. Homework Statement
A pendulum consists of a thin rod of length ℓ and
mass m suspended from a pivot ∇ in the figure to the
right. The bob is a cube of side L and mass M, attached
to the rod so that the line of the rod extends through
the center of the cube, from one corner to the
diametrically opposite corner (dashed line).
(a) Locate the distance of the center of mass
from the point of support.
(b) Find the moment of inertia I of the (entire)
pendulum about the pivot point.
(Hint: obviously it is too hard to find the
moment of inertia of a uniform cube about an
arbitrary axis through its center of mass by
integrating directly, so there must be some simple trick…)
(c) Write down the equation of motion in terms of I and any
other relevant parameters.
(d) Find the frequency of small oscillations.
I don't know if this is correct :
a/ The center of mass of the cube is at a distance L√3/2 to the corner where the rod is fixed. So the distance between the two centers of mass is L√3/2+l/2.
So the center of mass of the whole system is at a distance m/(M+m)*(L√3/2+l/2) to the cube center of mass and at a distance d=m/(M+m)*(L√3/2+l/2) - L√3/2 to the corner ?
b/ For the moment of inertia of the cube about an axis through the cdm and a corner, I found that it is equal to the moment of inertia about an axis that passes through the center of mass and the center of one face =ML²/6 and for the rod about the corner I=ml²/3
so Itot=ml²/3+ML²/6
c/ If we take φ to be the angle made by the pendulum and the vertical (passes through the pivot) we have to use I*d²φ/dt²=τ with τ the torque
I don"t know what is the expression for the torque here considering that for this pendulum the rod has a mass ?
Thanks
As I read the question, you are supposed to treat the rod as massless. Other than that, I agree with your answer ro a).
How do you arrive at your answer to b)? I agree with it, just interested in how you got there?
Using cosine direction, and the angle between the axis passing through a corner-com and an edge is 55°
So for c/ he torque is just -mgl sin(φ) ? But what if the rod has a mass ?
I just realized that although I agree with the result you got for that, it isn't actually what b asks for. They want the MoI about the pivot point.
So you need the MoI about an axis that's through the cdm and orthogonal to a long diagonal, and then you need to use the parallel axis theorem.
Where/how are you using that?
Where l is the length of the rod? Haven't you forgotten something?
Adding in terms for MoI and torque from the rod is pretty straightforward, but let's get the question as posed sorted first.
Oh I thought it was about the corner, i don't know why ..
But the moI that I found is about a diagonal, and the rod is aligned with the diagonal, isn't it the same then ?
if not, i don't think i understand your explanations...
I took the origin about the com
The moment of inertia Ixx Iyy Izz is ML2/6 and 0 everywhere else
No need to use the angle because we have I= (cos(a)2+cos(b)2+cos(c)2) ( ML2/6) and we know that for direction cosines : (cos(a)2+cos(b)2+cos(c)=1
Well, not quite. If you knew the MoI about an axis through the corner and perpendicular to the diagonal through the corner then that would do. You could get from there to the answer using the parallel axis theorem. But note that "through the corner" is not precise enough. You have to specify the axis direction.
Yes, that's excellent. I just had not been able to understand why you seemed to care about the angle before.
Anyway, that gives you MoI about any axis through the c.o.m., so in particular about an axis through the c.o.m. perpendicular to the diagonal. So what do you have to do to get the MoI about the pivot point?
Add Md² to the moment of inertia where d is the distance between the com and the pivot, that is √3L/2+l ?
Yes.
haruspex said:
Yes.
For the torque tou told me that I forgot something. The force is applied at the center of the cube so it would be -mg(l+sqrt(3)L/2) sin(theta) ?
Yes.
haruspex said:
Yes.
thank you for your help :smile:
right.
Adding the effect of the mass of the rod shouldn't cause too much of a headache.
If we add the effect of the mass of the rod, for the torque Is it just going to be -(M+m)g(l+√3L/2) sinθ ?
No, the torque can be calculated by letting the total weight act at the center of mass of the system.
So I just use what I found in a/ !
Thank you for the answer !
Yes. You will need the distance from the pivot to the CM of the system.
1. What is a Cube-Rod Pendulum?
A Cube-Rod Pendulum is a type of pendulum that consists of a cube-shaped weight attached to a rod by a pivot point. This type of pendulum is often used in physics experiments to demonstrate simple harmonic motion.
2. How do you solve a Cube-Rod Pendulum homework statement?
To solve a Cube-Rod Pendulum homework statement, you will need to use the equations of motion for simple harmonic motion. These equations include the period of oscillation, amplitude, and angular frequency. You will also need to consider factors such as the mass of the cube, length of the rod, and gravitational acceleration.
3. What are the equations used to solve a Cube-Rod Pendulum?
The equations used to solve a Cube-Rod Pendulum include:
  • Period of oscillation (T) = 2π√(L/g) where L is the length of the rod and g is the acceleration due to gravity
  • Amplitude (A) = maximum displacement of the pendulum from its equilibrium position
  • Angular frequency (ω) = 2π/T
4. What are the factors that affect the motion of a Cube-Rod Pendulum?
The factors that affect the motion of a Cube-Rod Pendulum include:
  • Length of the rod (L)
  • Mass of the cube (m)
  • Gravitational acceleration (g)
  • Amplitude (A)
  • Initial displacement or release angle of the pendulum
5. How can the Cube-Rod Pendulum be used to demonstrate simple harmonic motion?
The Cube-Rod Pendulum can be used to demonstrate simple harmonic motion by showing the relationship between the period of oscillation and the length of the rod. As the length of the rod increases, the period of oscillation also increases. This relationship can be seen in the equation T = 2π√(L/g). Additionally, the amplitude and angular frequency also remain constant for a given pendulum, demonstrating the periodic nature of simple harmonic motion.
