Cubic Feet of Argon required to fill a tank under vacuum
In summary, it will take about 250 cubic feet of gas to fill a tank that is under vacuum at 90 degrees Fahrenheit.
Nathan Smith
I have a tank that is 250 Cubic Feet.
The tank is under vacuum (1x10-5 Torr).. which is actually 1.93368e-7 psia.
How much Argon, in cubic feet, does it take to back-fill to atmosphere or 14.7 psia?
Ambient temperature in tank is 90 degrees.
Hello Nathan, :welcome:
I don't suppose you mean 250 cubic feet ? But then: what do you mean ?
Is it that simple from a vacuum?
Well, it will take about 250 cubic feet. Gas volumes are normally quoted at STP (standard temperature and pressure, which is 0 degrees C and 1 atm). You want 1 atm of pressure and 90 degrees. I'm going to assume, since your other measurements are in English units, that you mean 90 degrees F, which is 305 degrees K. So the volume of the gas will increase by 305/273, so you will need somewhat less than 250 cu ft of gas. You will need 250*273/305 = 224 cu ft of Ar to fill your tank. So one large gas cylinder will do it.
Pretend that the initial vacuum was perfect. Then your question is how much argon does it take to occupy 250 cubic feet at 90 degrees F?
The answer can not be given in cubit feet, because we don't know the pressure of the argon before it was put into this tank. You may be getting the argon from another tank at 1000 psi.
Wolfram alpha is a good source for such questions.
Now your next question is how many cubic feet is 25 pounds of argon? You have to tell me the pressure to answer that.
The source 130 PSI supply pressure from a 16 pack of Argon cylinders with 5721 cubic feet of gas storage.
It's been too long since I did this stuff but the Ideal Gas Law is used to determine how much volume an IDEAL gas occupies at different temperatures and pressures
https://www.engineeringtoolbox.com/ideal-gas-law-d_157.html
and the van der Waals equation is used to adjust for the fact that different gases behave differently and thus DEVIATE from the IDEAL equation's results. The following link explains it and has data for 200 or so different gases, including Argon.
https://www.engineeringtoolbox.com/...-Waals-equation-constants-gas-law-d_1969.html
Hope this helps. I'm not a physicist, just remember some of this from my brief stint in engineering school roughly 1000 years ago.
Tell me how big your piece of string tank is and I will tell you how big the argon becomes. At least for reasonable sized tanks.
BoB
What is the formula for calculating the cubic feet of argon required to fill a tank under vacuum?
The formula for calculating the cubic feet of argon required to fill a tank under vacuum is: (Volume of the tank in cubic feet) x (Pressure in psi) / (Tank pressure rating) = Cubic feet of argon required.
How do I determine the volume of the tank in cubic feet?
The volume of a tank can be determined by multiplying the length, width, and height of the tank in feet. Make sure all measurements are in the same unit (feet) before multiplying.
What is the average pressure rating for argon tanks?
The average pressure rating for argon tanks is typically between 3000-6000 psi. However, it is important to check the specific pressure rating of the tank you are using.
Can I use a different gas to fill the tank under vacuum?
While argon is commonly used to fill tanks under vacuum, other gases such as helium or nitrogen can also be used. However, it is important to consider the compatibility of the gas with the material of the tank and the intended use of the tank.
Are there any safety precautions I should take when filling a tank with argon under vacuum?
Yes, it is important to follow all safety guidelines and procedures when handling and filling tanks with argon under vacuum. This includes wearing proper protective equipment and ensuring the tank is properly secured and labeled.
  • Mechanical Engineering
  • Mechanics
  • General Engineering
10K
  • Poll
  • Other Physics Topics
17K
