Cubical block on a cylinder
  • Thread starter Saitama
  • #51
6,054
391
$$v_y=\frac{dh}{dt}$$
$$v_x=\frac{d}{dt}\left(\frac{L}{2}\sin\theta\right)$$
where ##v_x## is the horizontal velocity of block and ##v_y## is the vertical velocity of block.
I can replace ##\omega## with ##d\theta/dt##.
Am I correct?
By the way, if you think that the x-position of the CoM is ## \frac{L}{2}\sin\theta ##, you are mistaken (this is obvious from the vector formula).
  • #52
3,816
92
Yes, you are right, very sorry. I got the following x-position:
$$\left(R+\frac{L}{2}\right)\sin\theta-R\theta\cos\theta$$
This gives the same answer as yours.
Can you please tell me how do you find the horizontal and vertical components?
Are the following correct?
$$\vec u=\sin\theta \hat{i}+\cos\theta \hat{j}$$
$$\vec t=\cos\theta \hat{i}-\sin\theta \hat{j}$$
  • #53
6,054
391
Yes. Note that ## \vec t = \dot {\vec u} = - \dot {\vec t}##, which I used above.
Have you found the period of small oscillations?
  • #54
3,816
92
Here is my attempt at it:
$$E=\frac{1}{2}mv^2+\frac{1}{2}I_{CM}\omega^2+U(\theta)$$
$$\Rightarrow E=\frac{1}{2}m\dot{\theta}^2\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM}\dot{\theta}^2+U(\theta)$$
Since ##I_{CM}=mL^2/6##
$$\Rightarrow E=\frac{1}{8}mL^2\dot{\theta}^2+\frac{1}{2}mR^2\theta^2\dot{\theta}^2+ \frac {1}{12}mL^2\dot{\theta}^2+U(\theta)=\frac{5}{24}mL^2\dot{\theta}^2+ \frac {1}{2}mR^2\theta^2\dot{\theta}^2+U(\theta)$$
Differentiating wrt time,
$$\frac{dE}{dt}=\frac{5}{24}mL^2(2 \theta \dot{\theta})+\frac{1}{2}mR^2(2\theta\dot{\theta}^3+2\theta^2 \dot{ \theta }\ddot{\theta})+U'(\theta)$$
Using the small angle approximation, I neglect the terms involving ##\theta^2## and
$$U'(\theta)=mg\left(R\theta\cos\theta-\frac{L}{2}\sin\theta\right)\dot{\theta} \approx mg\left(R \theta \left(1-\frac{\theta^2}{2}\right)-\frac{L}{2}\theta\right)\dot{\theta}$$
$$\Rightarrow U'(\theta)\approx mg\left(R-\frac{L}{2}\right)\dot{\theta}$$
I feel I am doing it wrong. I have a ##\dot{\theta}^3## when I differentiate the energy equation which I think is wrong. :(
  • #55
6,054
391
The usual approach is this: form the exact equation for conservation of energy: KE + PE = KE(0) + PE(0). Use the small angle approx at this stage. KE has the form ## K(\theta) \dot \theta^2/2##. It is approximated with the lowest non vanishing order, which is simply ## K(0) \dot \theta^2/2 ##. PE is expanded as ## U(0) + U''(0) \theta^2 / 2 + ... ## We need more than just the lowest term of PE, because this will be differentiated later. So we end up with ## K(0) \dot \theta^2 + U''(0) \theta^2 /2 = K(0) \dot \theta (0) ##. Note ##U''## is differentiated with respect to its argument, not time (time diff is denoted by dots).
Now differentiate w.r.t. time: ## K(0)\ddot \theta + U''(0) \theta = 0 ##.
  • #56
3,816
92
Sorry voko, I can't follow this. I understand what you did to PE, can you please elaborate this one?
Thank you for being so patient!
  • #57
BruceW
3,611
121
Is ##K(0)## like an 'effective moment of inertia', evaluated at ##\theta=0## ?
  • #58
6,054
391
In #54, kinetic energy was shown to be ## \frac{1}{2}m\dot{\theta}^2\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM}\dot{\theta}^2 ##. This can be written as ## \left[\frac{1}{2}m\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM}\right]\dot{\theta}^2 = K(\theta)\dot \theta^2##, so ## K(\theta) = \frac{1}{2}m\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM} ##.
Now we approximate ## K(\theta) ## with just ## K(0) ##.
  • #59
3,816
92
Sorry for not being clear.
I already understood this but what I don't get is the following:
You approximate using Taylor expansion at ##\theta=0##, right?
$$K(0+\theta)=K(0)+K'(0)\theta+K''(0)\frac{\theta^2}{2}+....$$
Why don't you take K'(0) while approximating? :confused:
  • #60
6,054
391
Yes, the Taylor expansion is used for the approximation.
For both KE and PE we take the lowest-order terms, except that in PE we "ignore" the constant term.
We "ignore" for two reasons.
First, potential energy is defined up to an additive constant, so the constant term is meaningless physically.
Second, unlike the full expression for kinetic energy, there is no further multiplication with something varying, so if we retained only the constant term of PE, it would occur on both sides of the equation. Then it can be cancelled out, leaving no trace of PE in the equation at all (this is the mathematical consequence of the physical meaninglessness of PE's constant term).
As to why we take only the lowest terms, this is again for two reasons.
First, we want to obtain a linear equation in the end. This is probably the main reason for all the shortcuts.
Second, higher-order terms for small angles are much smaller. For example, 10 degree corresponds to 0.17 radian. That thing squared is 0.03 radian, almost an order of magnitude difference. This justifies our desire to neglect anything but the convenient terms :)
  • #61
6,054
391
I have checked what Kleppner has to say on small oscillations, and found that lacking. The form of the kinetic energy they have has no dependency on the coordinates, only on velocities, so there is no demonstration how to proceed in a case like you have here, even though it is taken from that same book.
Symon and Goldstein do a far better job at explaining that; Landau is also noteworthy.
  • #62
3,816
92
Thank you very much voko for such nice explanation. :smile:
I had
$$U(\theta)=mg((R+L/2)\cos\theta+R\theta\sin\theta)$$
$$\Rightarrow U''(\theta)=mg((R+L/2)(-\cos\theta)+R\cos\theta+R\cos\theta-R\theta\sin\theta)$$
For ##\theta=0##,
$$U''(0)=mg\left(R-\frac{L}{2}\right)$$
Since
$$K(\theta) = \frac{1}{2}m\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM} \Rightarrow K(0)=\frac{1}{8}mL^2+\frac{1}{2}I_{CM}$$
Substituting ##I_{CM}=mL^2/6##,
$$K(0)=\frac{5}{24}mL^2$$
As you stated before, from energy conservation we have,
$$K(0)\dot{\theta}^2+U''(0)\theta^2/2=K(0)\dot{\theta}(0)$$
$$K(0)(2\dot{\theta}\ddot{\theta})+U''(0)\theta\dot{\theta}=0$$
$$\Rightarrow \ddot{\theta}=-\frac{U''(0)}{2K(0)}\theta$$
Substituting the values,
$$\ddot{\theta}=-\frac{12g}{5L^2}\left(R-\frac{L}{2}\right)\theta$$
The time period can be easily calculated from the above equation.
Is the above correct?
I will have a look at them soon if they are available in my country. :)
  • #63
6,054
391
Looking good!
  • #64
3,816
92
Looking good!
Thanks a lot voko! :smile:
That was quite long for a single line problem. :tongue:
  • #65
6,054
391
You did a lot more than the problem required.
  • #66
3,816
92
Yes, but it was a great learning experience. :)
Related Threads on Cubical block on a cylinder
  • Last Post
  • Last Post
  • Last Post
