Curie's Law
  • Thread starter AStaunton
AStaunton
105
HI there..
The problem is given the below table for iron ammonium alum find C the Curie constant for this material..
T(in kelvin)..............X_m
15..........................(129*10^-4)
100........................(19.4*10^-4)
200........................(9.7*10^-4)
300........................(6.5*10^-4)
as X = C/T I thought simply rearrange:
=> XT = C
and so take any two values from above table and plug them into equation:
=> C = 15*(129*10^-4)K.A/T.m ---------where 15 and (129*10^-4) are taken from above table........
However, this is not the correct value for the curie constant for this material...
Can anyone please tell me where I am going wrong?
Thanks
Andrew
Answers and Replies
rock.freak667
6,223
31
It would be better to plot a graph of X vs 1/T. The gradient of that line will give you C.
AStaunton
105
Thanks for your reply...
using your method of plotting X V 1/T the value for C (curie constant) I get is around 0.2.....however, this is not in agreement with the answer that I have been provided with.. so am i perhaps overlooking a subtlety in the question?....the only information provided was the table I gave in the previous post...
rock.freak667
6,223
31
What was the value you are given?
AStaunton
105
It was incorrect to say I was given an answer...It is an online problem and all it tells is if an answer is right or wrong, and according to this, C=0.2 is not correct..
There is also another equation associated with C:
M=C*B/T
Would it be possible to use this to find value of C?
ie. is there some way of find M,B and T using the table I already posted?
Cheers
rock.freak667
6,223
31
M=C*B/T
I assume M is the same as Xm, if that is the case then you cannot get the value of C without knowing values of B for the same T.
If the relation you are given was Xm=C/T then that 'C' is not the same C as above.
Suggested for: Curie's Law
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
