• Support PF! Buy your school textbooks, materials and every day products Here!
Current across a resistor
  • Thread starter COKEDUDE
Number 15
[PLAIN]http://lookpic.com/d2/i2/386/kFYE2mOH.jpeg [Broken]
Rs=R1+R2+R3
Rpar=1/r1+1/r2+1/r3
I=V/R
1/(1/5+1/10+1/5)=2
Rtotal=7
I=21/7
I=3
I don't know what else to do to solve this problem. Any help would be greatly appreciated.
Answers and Replies
berkeman
Mentor
57,444
7,465
Number 15
Rs=R1+R2+R3
Rpar=1/r1+1/r2+1/r3
I=V/R
1/(1/5+1/10+1/5)=2
Rtotal=7
I=21/7
I=3
Welcome to the PF.
That's a good start. Once yuu figure out the parallel resistance of those 3 resistors, use the voltage divider equation to tell you what the voltage is across the 3 parallel resistors. that will then give you the current through that individual 10 Ohm resistor leg.
And the current is "through" the resistor. Voltages are across resistors, and currents flow through resistors.
vela
Staff Emeritus
Education Advisor
14,631
1,267
When you applied Ohm's law, you used V=21 V, which is the voltage across the entire combination of resistors, and R=7 ohms, which is the equivalent resistance of the entire combination, so the current I you found is the current that flows through that equivalent resistance.
What you're asked to find, however, is the current through just the 10-ohm resistor. One way to do that is apply Ohm's law to that individual resistor, and to do that, you need to find the voltage drop across the resistor, which you can find by applying Kirchoff's voltage law.
Related Threads on Current across a resistor
  • Last Post
  • Last Post
30K
  • Last Post
23K
22K
